Supercharger.
Discussion in 'Motorized Bicycle General Discussion' started by Yume, Jun 14, 2015.
  1. Yume
    Yume New Member
    Jun 13, 2015
    15
  2. Agreen
    Agreen Member
    Feb 10, 2013
    787
    4 stroke only. Forced induction is... complicated... for 2 strokes. Not impossible, but nearly.
    #2 Agreen, Jun 14, 2015
  3. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,466
    43
    considered turbo, but chinese engines just aren't stout enough in materials to do much more than they do stock
  4. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    951
    Problem is with our lay out you won't hold boost. The exhaust is right next to the transfer ports so realistically it will never really work on our engines. Some 2 strokes have different ways they work via methods I have no idea because I have never touched another 2 stroke, but are possible to boost. Realistically though it's not possible on your common china girl
  5. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,816
    10
    I wish this kit was available before I sold my Honda S-90.
  6. LandSpeedRecord
    Dec 11, 2014
    604
    Should still work on a China Girl if you have a large expansion chamber with a rapid taper on the trailing cone. From what I have seen of the turbo charged 2 strokes that is how they get a strong pulse to hold in the boost for lack of a better explanation. What we need here is for someone on the forum to purchase one and have it delivered to my work address so my wife didn't see it. Then I will install it, probably extend the crank on the Magneto side for simplicity to drive it. I actually have a YZ125 expansion chamber already sitting there I will cut up and donate to the project. Then I will test it extensively and provide you all with the results. Please feel free to PM me for details on shipping.
  7. LandSpeedRecord
    Dec 11, 2014
    604
    Then we can have a viable power adder an only 4 times the cost of the kit ha ha. Seriously though it looks pretty cool.
  8. dtv5403
    dtv5403 New Member
    May 4, 2015
    322
    I personally think it'd be easier to add an exhaust valve than a Turbo. Its not exactly a valve, but that's what it's referred to as, and it opens and closes automatically with engine rpms. They're used on racing two strokes.
  9. dtv5403
    dtv5403 New Member
    May 4, 2015
    322
  10. Tony01
    Tony01 Active Member
    Nov 28, 2012
    958
    25
    Look up buddfab 50cc on google. They built a 50cc streamliner that goes 150mph powered by a 20hp turbo 2-stroke, using a suck through turbo with tuned pipe. The tuned pipe charges the exhaust, matching the intake charge.
    I would be cautious with a suck through setup though. If you don't know what you're doing and you get early detonation the entire compressor becomes part of the combustion chamber. May be more work, but safer, to build a blow through with pressurized carb enclosure and a pressure-checked fuel pump.
  11. boxcar
    boxcar New Member
    Dec 18, 2014
    358
    I think it may be less work to slap a YZ 125cc engine in the thing and be done with it....
