Sturmey Archer internal hub help
Discussion in 'Hubs, Gearboxes, Sprockets and Chains' started by mike_ric, Oct 2, 2014.
  1. mike_ric
    mike_ric New Member
    May 4, 2011
    22
    Hi, I have a Sturmey Archer XL RD5(w) internal five speed hub. In general it works pretty well, however recently I've noticed when I'm testing my motorized bike by pedaling only (this happens under motor power too.) under slight load (up a mild hill) in first and second gear only that the hub will disengage, my pedals will spin for 1/2 to 3/4 turn, then the hub will engage again.
    To shift I stop pedaling, switch gears, then lightly start pedaling again (on a flat road) then I will pedal a few rotations until I get to my slightly inclined driveway, then the disengagement happens.
    I've adjusted the cable tension back and forth the full range from when first gear doesn't engage at all on one end of the adjustment (too tight) to where it fully engages, then doesn't engage because the cable is too loose. I know where the sweet spot is for excellent shifting action on all five gears, but no matter how I adjust it 1/4 turn at a time I still get the disengagement, freewheeling, then engagement again.
    I have about 300 miles on this new hub.
    Can anybody offer suggestions?
    My local Sturmey Archer dealer noticed the cog-side wheel bearing was a little loose, so he tightened that, but I haven't yet remounted the wheel to test.
    Thanks.
  2. crassius
    crassius Well-Known Member
    Sep 30, 2012
    4,032
    153
    old motorcycles used to use selectors that were probably similar (burman, enfield, and 4 cyl indians were some)
    throwing out of gear was common when the shift rod was a bit off alignment, or when the detent spring was adjusted to loosely
    I'd expect these to be similar, so a loose bearing might cause that.
  3. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,707
    The loose bearing could be the culprit because any play in the system can make adjustments near impossible to get right.
  4. MotoMagz
    MotoMagz Well-Known Member
    Aug 2, 2010
    1,610
    561
    The hub comes with 2 different mounting nut packages and a new sckool and old school selected guide. Do not mix..use one or the other. Then put iit n 2nd gear..next adjust indicator so yellow is barely seen through guide hole.
  5. mike_ric
    mike_ric New Member
    May 4, 2011
    22
    Thanks for the tips everybody, I'll put the wheel back on tomorrow and hopefully it'll be working the way it should.
  6. crassius
    Sep 30, 2012
    4,032
    153
    not sure how much force is applied on bikes, but on 'cycles leaving it unadjusted for a short time can deform the seats such that throwing out of gear can become permanent without major repair work
  7. mike_ric
    mike_ric New Member
    May 4, 2011
    22
    I put everything back together and no luck, still issues with mostly second gear. I'm pursuing options now about getting another hub, I'm done fooling with this one. I probably trashed it during the testing phase of building the bike.
  8. The_Aleman
    The_Aleman Active Member
    Jul 31, 2008
    2,655
    <removed out of protest to certain "staff" practices in this forum.>
    #8 The_Aleman, Oct 10, 2014
  9. mike_ric
    mike_ric New Member
    May 4, 2011
    22
    Update: I replaced the hub with another new SA and all is working well now. I also replaced the original 13 gauge spokes with thicker 12 gauge since the original spokes stretched quite a bit. Hopefully this setup will last!
  10. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    I don't have a shifter bike and I'm not knowledgeable about the inner workings of the multi speed hubs, but I just wanted to say congrats on getting your bike fixed and rolling again.
    xct2
    Map
