stuck
Discussion in 'Motorized Bicycle General Discussion' started by rjepp, Apr 24, 2010.
  1. rjepp
    rjepp New Member
    Apr 24, 2010
    7
    I am not getting spark, plug is wet when pulled after trying to start. If I have the wrong plug would I still get a spark ?
  2. tyrslider
    tyrslider New Member
    Sep 26, 2008
    958
    yes you would. either cdi is hooked up wrong or is defective (unfortunately fairly common).
  3. rjepp
    rjepp New Member
    Apr 24, 2010
    7
    thanks, I also noticed a little water in the mag. housing, thats not a good thing?
  4. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    A wet mag might be fried.
  5. rjepp
    rjepp New Member
    Apr 24, 2010
    7
    thanks, going to order new one now
  6. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Water inside the magneto cover is not a good thing. It's a good idea to seal the hole where the ignition wires exit the case with a glob of silicone sealer. There should be a gasket on the mag cover too but even so I like to seal it with a little silicone. That assures that moisture cannot get in and damage the magneto.
  7. charles.paskell
    charles.paskell New Member
    Feb 25, 2010
    201
    i had 2 order a mag when i had watter in it so i ordered another one and i put silicone on the wires after putting the new one in where they meet the white tube (gasket?)and on the inside and outside of the crank case where the wires come in/out also on top of the crank case all around works just fine.
    having other problems but thats another story.
    #7 charles.paskell, Apr 24, 2010
  8. Bikeguy Joe
    Jan 8, 2008
    11,529
    If you had water in there, did you try drying it out before you bought a new one?
    How about checking other things in the ignition system, like the plug wire, or the kill switch?
