Sprocket spacing on old coaster brake hub?
Discussion in 'Motorized Bicycle General Discussion' started by Strapnug, Mar 13, 2010.
  1. Strapnug
    Strapnug New Member
    Mar 13, 2010
    Hi- new to the forum. Have browsed the site, but none of the fixes seem to work with this problem.
    I just received my BGF kit this week and started with mounting the sprocket. This is on on old 60's
    Otasco 26 inch cruiser with a Shimano "D" type coaster brake, which is in excellent condition. With the lever arm off and dust cap removed, if I lay the sprocket flush to the spokes with no rubber installed and install the brake lever arm back on the flats of the bearing cone, there is absolutely no clearance between the sprocket and the inside surface of the arm, just a shear, rub fit. If I install the t rubber shim (.300 thick) between the sprocket and the spokes I will come up about .300" plus some clearance short, for the brake lever arm to seat on the square flats of the left bearing cone. I can
    only see making a special spacer about a half inch thick which would fit over the flats of the cone
    on one side and have raised flats on the outside to engage the flat/hole in the brake arm. Then bend as necessary to clear the bolt heads. My question is, does anyone make such a part to shim out the arm where it will clear the sprocket with the rubber spacer installed? Probably not your typical modern coaster brake. Or is there a better way!--Regards--James Parker in Wichita
  2. RedB66
    RedB66 New Member
    Dec 28, 2007
    1,023
    Pictures would help. The coaster brake hub/arms can be a pain. Have you considered an adapter?
    SPROCKET ADAPTER
  3. macattie88
    macattie88 New Member
    Dec 2, 2009
    102
    i bought one for my delmar...it saves soooo much aggrevation! worth every penny...i tried the rag joint route and found it to be very frustrating to line up and it looks like crap...jims adapter makes it a snap and really looks great too.
  4. K.i.p
    K.i.p New Member
    Nov 8, 2009
    340
    Made my adapter by hand on some manual machines, regardless, I never even took the rag joint hardware out of the bag. The adapter covers several problems all at once, the run out and concentric issues are nill. I don't know for sure about Jim's I made mine narrow enough for side to side alignment as well. I would assume his are engineered the same way.
