Sprocket clearance
Discussion in 'Motorized Bicycle General Discussion' started by Comrade Alfonzo, Jun 16, 2010.
  1. Comrade Alfonzo
    Comrade Alfonzo New Member
    Jul 15, 2009
    143
    Because of narrow chainstays on my frame, yes I have added as many spacers as possible, I do not have enough clearance between the sprocket teeth and the frame, will turning the sprocket around so the mirror side faces out kill me, also it is one of the kit supplied 44T sprockets. WILL THIS KILL ME?
    Also because of my chain tensioners addiction to playing in the spokes the chain has a slight twist towards the bike in a section, WILL THIS KILL ME?
    Thanks for all the help, I would like to live to ride :-||
  2. Cogswelln
    Cogswelln New Member
    Dec 6, 2009
    208
    switching the sprocket around will not be harmfull at all, the chain should be replaced, and the chain tensoiner should be perfectly aligned with the chain.
  3. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    So long as the chain runs straight and true between the engine sprocket and wheel sprocket, do whatever you have to do. A "slight twist towards the bike in a section" does not sound too good to me.
    It should not kill you if the chain flys off while you are going 1 MPH. Any faster and all bets are off.
    Follow Cogswelln's lead as well.
  4. nidyanazo
    nidyanazo New Member
    May 25, 2010
    316
    Depends on the chain. Some of the cheaper ones have alot of lateral play in them (like a multi speed chain) so it can switch cogs. Try a single speed (usualy chrome plated) chain or a HD 415 chain.
  5. Salty Gator
    Salty Gator New Member
    Aug 3, 2009
    672
    Alfonzo.....you did good to ask these questions....and I agree....I'd rather be remembered for being alive than a road named after me......
    Salty.shft.
  6. Comrade Alfonzo
    Jul 15, 2009
    143
    Thanks for all the help, I will be ordering a new chain, and flipping the sprocket tonight., I also needed a new kill switch, I think a 12V toggle with the two posts out the bottom, I can ziptie to the handle bars, no cool covers though.
