Sprocket Adapter
Discussion in 'Motorized Bicycle General Discussion' started by Comrade Alfonzo, Jul 19, 2010.
  1. Comrade Alfonzo
    Comrade Alfonzo New Member
    Jul 15, 2009
    143
    I'm thinking about getting a Sprocket Adapter from Pirate Cycles and I'm not sure where to measure on the hub to check for fit. It is and older Peugeot Mountain bike, with the original wheel I think.
    Thanks
  2. azbill
    azbill Active Member
    May 18, 2008
    3,367
    you need to measure the diameter of the hub itself (inside the spokes)
    and also the distance across the flange (the part of the hub where the spokes go through)
    hope that helps :)
  3. Comrade Alfonzo
    Jul 15, 2009
    143
    Well the website only gives one measurment, so I don't know which one to use, has anyone used a hub adapter on a free wheel mountain bike hub
  4. azbill
    May 18, 2008
    3,367
    if the wheel has normal sized spokes,,,just the hub measurement is needed
    you only need the flange diameter if using heavy-duty (thick) spokes
