speedometer computer
Discussion in 'Motorized Bicycle General Discussion' started by Legwon, Mar 31, 2013.
  1. Legwon
    Legwon New Member
    Mar 2, 2013
    248
  2. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,773
    88
    I read it as 60cm - got glasses?
  3. Legwon
    Legwon New Member
    Mar 2, 2013
    248
    look at the drawing
  4. Powertool
    Powertool Member
    Jul 8, 2012
    230
    might not work with motorized bike
  5. Legwon
    Legwon New Member
    Mar 2, 2013
    248
    i was thinking the same thing when i read the instructions, but its not wireless. so there wouldn't(shouldn't?) be any interference.
  6. Powertool
    Powertool Member
    Jul 8, 2012
    230
    oh, thought you had a wireless unit, my bad
  7. 2door
    2door Moderator
    Staff Member
    16,310
    Even wired speedos can sometimes be affected by the ignition system. There is a lot of discussion here regarding speedometers and interference. Use the Google Custom Search, type in 'speedometer' and you'll have plenty to rear.
    As for instructions that have been translated into English, you never know what you'll see/read. The booklet that comes with the Bell speedo shows the magnet/sensor mounted on the left front fork but the instructions say to mount it on the right side :)
  8. maniac57
    Oct 8, 2011
    4,486
    7
    Just be sure the magnet is close to the pickup...that's the 6cm measurement, (should be 6MM) It does not matter where you mount it as long as it is close to the pickup as the wheel spins.
  9. 2door
    2door Moderator
    Staff Member
    16,310
    And look for the little arrow on the sensor. The magnet on the spokes should line up exactly with that arrow. Otherwise your speedometer won't work well.
  10. Legwon
    Legwon New Member
    Mar 2, 2013
    248
    actually is 1.5mm max spacing between magnet and sensor :s tight fit.
    right, ill have to look at that .
  11. LR Jerry
    LR Jerry Active Member
    Dec 19, 2011
    1,027
    My techometer/ hour counter and wired speedometer both say to keep separate from other electric systems.
  12. Wild Bill
    Wild Bill New Member
    Jan 29, 2013
    478
    I have a wired speedo and it didnt work until I changed the plug wire to a carbon core wire. Later after I installed the Jag cdi it quit working again (Wacky readings) even after I put a carbon wire on the jag coil so I ordered an old skool cable drive speedo.
  13. crassius
    Sep 30, 2012
    3,773
    88
    reading the instructions gives accurate measurements - 'course some folks only look at the pics : (
  14. biknut
    biknut Active Member
    Sep 28, 2010
    6,379
    It's a typo. What they're trying to say is the transmitter can't be more than 60cm from the computer.
    Since that's a wireless speedo, you'll probably be getting RF interference at some engine speeds.
