Spec sheet
Discussion in 'Motorized Bicycle General Discussion' started by graydog8josh, Jul 11, 2013.
  1. graydog8josh
    graydog8josh New Member
    Nov 23, 2012
    447
    I was trying to write a spec sheet for my bike. I havent found my tape measure to measure the Length width and height so i just guessed but otherwise from looking at the skyhawk website and claims from vendors this is what i got so far (correct me if im wrong):
    SPECIFICATIONS
    ENGINE
    TYPE AIR COOLED 66CC PISTON PORTED
    DISPLACEMENT 66 CC
    BORE X STROKE 47 x 38MM
    COMPRESSION RATIO 12:1
    CARBURETION 14MM SLIDE VALVE & FLOAT
    HORSE POWER 4.5 HP/8000 rpm
    IGNITION CDI
    STARTING PUSH START
    TRANSMISSION SINGLE SPEED MANUAL
    FUEL CONSUMPTION ~ 100 MPG
    CHASSIS
    FRAME HARDENED STEEL
    SUSPENSION FRONT SR SUNTOUR SUSPENSION FRONT FORK
    SUSPENSION REAR HARDTAIL
    BRAKES SHIMANO LINEAR V-BRAKE
    TIRES 26” X 1.95 MTB SLICK TIRES 60 PSI
    DIMENSIONS
    LENGTH xx
    WIDTH 26.5”
    SEAT HEIGHT xx
    WHEELBASE xx
    DRY WEIGHT 65 LBS
    FUEL CAPACITY 0.8 GAL
  2. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,825
    12
    Sorry to change the subject, but did you decide against building the electric ripper? That thread got plenty of advice and discussion.
  3. graydog8josh
    Nov 23, 2012
    447
    no just waiting on funds and motivation. This spec sheet is what i turned into the mechanical engineering department at my school to try to generate interest and possibly funding to keep building. They said they were interested. It would be great to get engineers working on advancing bike technology.
  4. Huffydavidson
    Huffydavidson STREETRACER/MANUFACTURER
    Jan 29, 2012
    1,075
    Who are these venders? Who did you purchase your engine from ? 12:1 compression ? With a stock head? What head are you running? Carb?
  5. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    Huffy, he has an Arrow engine. Its got a reed valve, boost porting and a mikuni flat slide carb. I believe it also comes with an Arrow exhaust.
  6. Huffydavidson
    Jan 29, 2012
    1,075
    This clears it up a bit bean . But heres the thing , that info should at the top of the sheet don't you think? And the 4.5 hp engine, doesn't it come with a 15mm SHA clone as I recall?
    #6 Huffydavidson, Jul 12, 2013
  7. bigbutterbean
    Jan 31, 2011
    2,417
    You might be right. I know one of his engines comes with a mikuni flat slide and one comes with an SHA clone, but I can't remember which is which. The spec sheet is to turn into the engineering department at his college. I doubt they will know the difference between a stock motor and an arrow motor. He should put reed valves and cylinder porting on the spec sheet though. These guys are engineers, I'm sure they know a thing or two about performance tuning in two stroke engines and that info would be helpful to them. But its Josh's spec sheet, he'll present it however he sees fit.
  8. graydog8josh
    Nov 23, 2012
    447
    im running the nt carb. Im running whichever head comes with the 4.5 motor from arrow and his torquer 2 exhaust.
  9. MotorBicycleRacing
    Jul 28, 2010
    5,706
    34
    The Arrow Motorized Cycles 4.5HP street racer motor comes with a billet head from CR Machine.
    It also comes with a 15mm flat Slide carburetor and filter so I am wondering
    why you a using a NT carb which won't perform as well?
    Why doesn't your spec sheet mention the reed valve?
    #9 MotorBicycleRacing, Jul 12, 2013
  10. graydog8josh
    Nov 23, 2012
    447
    i was having trouble with that carb with air leaks so i used the stock. I didnt know where to put reed valve in the set of info that i had, so i had left it out. Also, i didnt know which head the cr machine head was whether it was the 5.5 the 6 or the 7 so i wanted to find a place in that set of info for that too, so i could accurately calculate the compression but i didnt know that info.
    The main reason i reached out to the forum is if someone knows the cc of the chamber in the head. Also if you think i should put more info on maybe indicate where you think it should go or specifically what corrections i should make. like: you should put "intake: reed valve " in the engine section. I just looked at this sheet to model my specs off of:
  11. Huffydavidson
    Jan 29, 2012
    1,075
    Sounds like this has a gray area? Hhuummmm
  12. mrfubs
    mrfubs New Member
    Jun 13, 2013
    294
  13. Huffydavidson
    Jan 29, 2012
    1,075
    No I don't build knock -offs.knock offs are imitations . I build race engines. Knock-offs are fake cheap junk.dance1
  14. mrfubs
    mrfubs New Member
    Jun 13, 2013
    294
    Do you balance and true the cranks?
  15. Huffydavidson
    Jan 29, 2012
    1,075
    Just for friends and family .it's too much headache to do it for outsiders .brnot
  16. graydog8josh
    Nov 23, 2012
    447
    Please don't jack my thread...
    I thought other people would be interested in a spec sheet....
    It does bring up a good point, i dont have access to a dyno but i wonder how much my actual performance is suffering due to the NT carb.
    I weighed my bike on scales and it is actually 63lbs with a bit of fuel in the take so its probably about 60 lbs dry. I dont like to keep my tanks full in case of spills so i dont have a wet weight but i could probably just derive that from weight of the fuel.
  17. Huffydavidson
    Jan 29, 2012
    1,075
    Sorry josh he came me my bad please forgive me . Your performance suffering because in NT I would say lot . when I first started out and I was running a manic mechanic intake a boost bottle and then I got my DAX RT that was a big difference there. and I'll say this I'll never go back . I don't who he gets his clone carb from but its not want to be a clone their selling on Fea-bay. there should be a thread here on how to tune the clone , if not there should be one . No I won't do it . or contact your supplier .
  18. bigbutterbean
    Jan 31, 2011
    2,417
    Josh, a gallon of gas weighs 6.2 lbs. The larger size kit tanks are 2.5 liters, which is roughly 2/3 of a gallon, so somewhere around 4 lbs with a full tank. If you've got the smaller size tank, I'm not sure how much gas they hold, but most likely you've got the larger tank. Unless you're not running a kit tank, then I've no idea how much gas you can hold. Just a little fyi.
  19. graydog8josh
    Nov 23, 2012
    447
    that is a significant amount of weight. I mean i knew gas wasnt light but i didnt really care too much to factor it in. That makes me feel like i should never run a full tank unless im treking across a few towns. I guess i have the 2.5 liter tank, i thought it was a 3 liter tank though. I know it has the m6 mounting hardware which is much more conveinent than the tiny m4 nuts that don't hold the tank on for anything.
