Spark plugs
Discussion in 'Motorized Bicycle General Discussion' started by fraser, Feb 29, 2012.
  1. fraser
    fraser New Member
    Feb 11, 2012
    19
    Hello having a bit of trouble with my engine. I am going to try and switch out spark plugs. Does anybody know which NGK spark plug to buy for my engine kit??
    It's a zoombicycles 66cc 2 stroke it's spark plug in currently has is called a great master model # 4118C
    Stock with the bike
    Thanks
  2. 2door
    2door Moderator
    Staff Member
    16,308
    30
  3. bandito
    bandito New Member
    May 22, 2009
    783
    What motor? Torch is a chinese brand. Go name brand ie. NKG ie. Get rid of the torch brand.
  4. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    I used the B6HS for several years on all my 2-strokes. Great all-around plug, IMO.
  5. bandito
    bandito New Member
    May 22, 2009
    783
    Torch is a chinese brand.......nkg is nippon,,,..........buy the plug.
    f
  6. darkhawk22
    darkhawk22 New Member
    Aug 17, 2010
    733
  7. biknut
    biknut Active Member
    Sep 28, 2010
    6,378
    NGK B5HS works well, and a BP5HS, which is extended tip, works a little better for me. A 6 is a little cooler plug. They work well too
  8. Saddletramp1200
    Saddletramp1200 Custom MB Buiilder
    May 7, 2008
    1,421
    It really depends on where you live. Yea right, your thinking. The thinner the air the "hotter" the plug needs to be. At Sea level the B6 HS is fine. The numbers go down, the heat goes up.
  9. rjs467
    rjs467 New Member
    Feb 5, 2012
    12
    I purchased two NGK B-6L plugs at my Canadian Tire store Feb 27/2012. I installed one on the bike's motor. I am waiting for the summer of 2012, hoping that this BGF 66 CC gas engine won't let me down. The instructions for this motor say to install a NGK BP-6L if you can find one. Otherwise, install a NGK B-6L, as I did. And if this can't be found, go for the NGK R7-HS.
  10. Saddletramp1200
    May 7, 2008
    1,421
    I can't tell anymore, but think The Letter L means long thread. It's a winner if you want to put a sun roof in the piston.
  11. donphantasmo
    donphantasmo Member
    Oct 3, 2010
    360
    B7hs is the median. B8hs is a cooler spark. B6hs is a hotter spark.
    Use B7hs. It should be good
  12. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    On my slant head 66 cc I use the NGK BP7HS thats an "s" as in sleep for lack of a dirty word
  13. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    You guys know Snoop Dogs favorite kind of weather ?
    Drizzle
  14. DIANY
    DIANY New Member
    Mar 8, 2012
    127
    nice one jumpa, nice!
  15. diesel278
    diesel278 New Member
    Apr 6, 2012
    12
    and he gets his whites cleaner with,,,,
    Bleaaatch
