Sorry for a newbie qestion...
Discussion in 'Motorized Bicycle General Discussion' started by TemporalRaider, Apr 18, 2011.
  1. TemporalRaider
    TemporalRaider New Member
    Apr 13, 2011
    7
    So I am new, Got a bike from Helio bikes, had some problems, as everyone does from all the posts I have read (and I hope I have searched enough as I would hate to be asking a question that has already been answered)
    So my problem is I managed to break a link in my drive chain (415 type) First, can I just put a second master link in the spot I broke? Is breaking a link indicitive of a bad chain or some other problem I am too new to know about? (I did find the post on grinding down the housing for the clutch actuator housing, which I plan on doing) Otherwise I love my bike. Hills I would have had to walk/give up on, now I just give it some gas and a little peddle power and off I go, Friggin Awsome. The site here is great and the information is invaluable. If you guys want pictures of any of this stuff just let me know. Oh the engine is a 2-stroke china girl, as apparently it doesnt matter what name is tacked on the side, its the same on the inside.
  2. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    There's no reason to apologize, if anything such assistance is part of the point of this forum after all lol
    While you can ofc simply replace the broken link with a master, it would be better to invest in a chain breaking tool as then you're able to fabricate any length of chain you wish. While there are many types of chain breakers, I prefer the following style as it seems far more capable of dealing with a wider variety of chain as well as being durable: Amazon.com: MOTORCYCLE DIRT BIKE ATV CHAIN LINK BREAKER TOOL: Automotive
    As for the chin itself, the kit supplied chains are renowned for being of an extremely low quality. The 415 is often replaced with a #41 roller chain which is slightly wider but has the same pitch. It can be found at almost any farm & tractor supply or a decent hardware store for roughly $10 for 10' for the generic "heavy duty": Amazon.com: Roller Chain: Everything Else
    Here's a handy chain chart in case you need it;
    Azusa Engineering, Inc. Online Catalog - Roller Chain, Motorcycles, etc.
    Welcome to the forum BTW ;)
  3. TemporalRaider
    Apr 13, 2011
    7
    Thank you. I ordered some new chain and a master link. Guss we will see what happens. I like how the chain breaker looks like it uses some chian links in its construction, just kinda ironic, lol.
  4. matthurd
    matthurd New Member
    Dec 13, 2010
    817
    i like the kmc 415 chains, they hold up well and are a reasonable price. well suited for what we're doing from what iv'e seen.
    also that chart barelyawake posted is great, hadn't seen that before.
  5. Allen_Wrench
    Feb 6, 2010
    2,787
    Ya know, I'm wondering why a 415 chain broke. Before you put another chain on there, I would check your allignment fore to aft. Check the caster and camber of your rear wheel too, it should be bolted straight up and down, and pointing straight in line with the frame. You may want to see if your engine is tilted at all. And is there anything behind that little sprocket cover that might have gotten stuck in your chain?
    I'm one of the more anal-retentive people here, I'm sure, so if that sort of thing happened to me I'd come up with a "laundry list" of things to check. But, hey, it keeps me out of jams sometimes.
  6. TemporalRaider
    Apr 13, 2011
    7
    so i bought the bike all asembled and ready to go (ok, mostly, i had to do some tweeking) i am mechanicly enclined, but im not sure how to check weather everything is straight, it looks close enough to me, but im not sure how close it has to be, and how i would fix it if its not. Can i get an explanation of how to check if stuff is straight enough, or if i took a bunch of good pictures could u folks tell?
  7. BarelyAWake
    Jul 21, 2009
    7,209
    Unfortunatly this is one of the few things that's really hard to tell w/just pics as perspective gets a lil weird w/such :( ...but ofc we love pics here so post 'em ifn ya got 'em lol
    There's a couple few ways to check chain alignment, checking for chafe/wear on the inside of the engine's sprocket cover is a good start - but two of my faves are hunkerin' down behind the bike and sighting down the rear sprocket to the engine's sprocket (like a rifle's sights) looking for twists or misalignment, another way is to suspend the bike so the rear wheel is off the ground and slowly spin the rear wheel while watching the sprockets teeth as they protrude through the chain - ideally they'll be in the middle of the chain at both the top and bottom of the sprocket. If they're all to one side your sprocket is too far in or out and/or not aligned with the engine's, if they're on one side at the bottom and the other at the top yer wheel may be crooked in the bike, if the teeth "wander" from side to side as you slowly spin the wheel the sprocket itself is not true with the wheel.
    You can also take a long straight edge (like a contractor's level) and place it flush on the side of the engine (sprocket & mag covers and/or clutch cover) and towards the rear of the bike - sighting along it to see if the engine isn't "twisted" in the frame. Don't take it too seriously as the covers aren't exactly true lol, but comparing the difference between the two sides outa give you an idea if it's really bad or not ;)
    Allen Wrench is defo right about lookin' for causes, somethin' is defo a bit wonky - but if everythin' seems true enough, there's also the chance ya just got a bum chain. I got a kit chain one time where the rollers were only 1/2 as wide as they should have been, leaving the link pins partially exposed o_O In alla my years of tinkerin' I'd never seen such an example of poor quality control lol
    #7 BarelyAWake, Apr 19, 2011
  8. TemporalRaider
    Apr 13, 2011
    7
    so i looked at my bike this morning and it looks like the motor is cocked over a few degree's. lol, um, how do i fix it? it looks like i could just losen the nut on the left side of the rear brackat and tighten the one on the right, but im not sure if that would do it.
  9. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    If the seat tube is not quite big enough for the mount to sit flush all the way around it, the motor will get crooked. Split a piece of 1" conduit to shim it up, and that will take care of it.
  10. TemporalRaider
    Apr 13, 2011
    7
    One inch conduit? Is that something I can pick up at home depo? Will they know what u mean by that?
  11. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Yeah, but you might only find a 10' piece of straight conduit (also called EMT). When I did mine, I bought a 90 degree curved elbow with enough straight end for me to work with. Cheaper and it fit in my car.
    But look at your rear mount and make sure that's your issue first.
  12. TemporalRaider
    Apr 13, 2011
    7
    just got home and it looks like the tube may be too big for the bracket on the engine, if only slightly, i cant tell for sure because it came built with a pice of ruber between the engine mount and the seat tube.
  13. BarelyAWake
    Jul 21, 2009
    7,209
  14. matthurd
    matthurd New Member
    Dec 13, 2010
    817
    what do you think about cork? like cork wrapping tape used on handle bars? that's what i was considering using to fill space on my mounts, cork is known to stop vibrations pretty well but i'm not sure how much that applies to what we're doing.
  15. BarelyAWake
    Jul 21, 2009
    7,209
    ^ sorry, it's far easier to C&P Tom's well phrased post than to type it again lol ;)
    #15 BarelyAWake, Apr 20, 2011
  16. matthurd
    matthurd New Member
    Dec 13, 2010
    817
    ok so corks probably better then inner tube but still not a good idea, what's the best solution for mounting to a frame thats frame tubes are slightly smaller then the motor mounts?
    my bikes frame doesn't quite fill out the shape of the mounts enough for my preferences.
  17. BarelyAWake
    Jul 21, 2009
    7,209
    Shims made frm aluminum cans come to mind, aluminum conduit/pipe/tubing if the can material isn't thick enough - aluminum is awesome for many reasons, being easy to work w/just basic hand tools is ofc one of 'em :D
  18. matthurd
    matthurd New Member
    Dec 13, 2010
    817
    ok thanks for ideas/info barely.
