Some ?s
Discussion in 'Motorized Bicycle General Discussion' started by xzackx, Jul 14, 2010.
  1. xzackx
    xzackx New Member
    Jun 30, 2010
    44
    ok well ive put about 100 miles on my schwinn occ stingray 80cc bike.
    a few days ago my tank sprung a leak, took it off, i notice its leaking from the bolts out of the tank. any fix?
    i have also noticed there is a oily black spatter all over the tube in front of my engine and all over the bottom end of the engine, as well as on top of the head in the front..anyone know what causes this?
    and where can i get a long exhaust for this chopper the exhaust on it i bent to fit but i want the one that goes out the back custom make? or buy?
    thanks
  2. charles.paskell
    charles.paskell New Member
    Feb 25, 2010
    201
    xzakx- sounds like you have some loose bolts causing the oil splatter, as for the exaust i think you can buy one
  3. xzackx
    xzackx New Member
    Jun 30, 2010
    44
    ok so is it 12lbs for the headbolts? or what? someone told me but i forget. and where can i get the exhaust i looked for the berry's exhaust but cant find thanks
  4. ilikebike
    ilikebike New Member
    Jul 14, 2010
    another question, I just got my first kit and am having some troubles installing it. first, i cant get the engine bolted down bc the frame is to thick second, i am trouble getting the sprocket to fit bc of coaster brakes...any tips? thanks
  5. charles.paskell
    Feb 25, 2010
    201
    xzakx- look on ebay for a exhaust they usually have them for pocket bikes
    Ilikebike-you might need the bigger bracket kit as for coster brakes i cant tell you
    ******There is a search engine at the top of this page (and every page)******
    xzack- type in: custom exhaust
    ilikebike-type in: coaster brake
  6. scotto-
    Jun 3, 2010
    6,530
    6
    Who am I to say but you really should start your first post as an introduction....and then post your own question, not jump into someone elses.
    But since you did, do a search before posting...and oversized brackets for your engine mounting can be found from many vendors on this page and just remove the dust cap from the coasterbrake and bend the anchor arm so it clears the sprocket.
    Oh, welcome to the forum by the way!
  7. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    If you know someone who has a cutting torch just enlarge the center hole in your sprocket so it will fit over dust cover, I would not remove it you will just be opening up your wheel bearing to dirt which will cause the bearing to wear out much quicker. Good luck with your build..!
  8. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Type in different Questions in the search bar above the bike berry add at the top of the page
  9. Venice Motor Bikes
    Mar 20, 2008
    6,170
    Sound like all the oil is from a bad exaust gasket.
  10. xzackx
    xzackx New Member
    Jun 30, 2010
    44
    ok ty i'll have to look into buy some material for it
  11. bairdco
    Aug 18, 2009
    6,350
    25
    make sure your exhaust pipe flange is straight and uh, whaddayacalit, y'know, not bent.
    sometimes they don't mate up flush with the port, and the gasket doesn't have enough "give" to make up for it.
    usually, you can sand it down using a flat surface to take out any imperfections.
    as far as the tank goes, those bolts suck. if you tighten them down to much, you crack the welds. sometimes, even if you don't tighten them down to much they'll leak.
    if you drain the tank, then use a wire wheel or sandpaper or whatever and grind off all the paint around the studs, make sure it's clean, free of all gas and oil. JB weld works pretty good.
    there's a product called "seal-all" that ace hardware has that'll work temporsrily, too. it's like a glue that can go on over gas.
  12. xzackx
    xzackx New Member
    Jun 30, 2010
    44
    yea i got some im gonna try and already ordered a new exhaust pipe got a barrys thunderpipe from ebay hope it sounds nice and works and got some gasket material to cut and fit hope it all works out and btw yea i blew the exhuast gasket
