So Close
Discussion in 'Motorized Bicycle General Discussion' started by Comrade Alfonzo, May 16, 2010.
  1. Comrade Alfonzo
    Comrade Alfonzo New Member
    Jul 15, 2009
    143
    I have finally got my bike working after 10 months. The kill switch does not work, disturbing, and the chain tensioner won't tighten any more but still took a dip in my spokes. Would Loctite from the frame to the tensioner hold it. Also, which way do I adjust the idle to slow it down, I clutched in to turn around and pedaled up to speed then let out the clutch, and it was still revving high enough to rip the chain off, this is probably because I have too much chain on there, but it is still idling very high. Also when I get a switch to replace this crappy kill switch how should it be wired. Thanks for everybody's help. Especially Flybytaco for the chain. dance1
  2. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    You can splice into the black wire(ground) to put a toggle switch on,im just guessing.
    Idle screw counter clockwise(left) to lower idle.
    Some people drill a tiny hole threw the tensioner into the bike frame and add a small screw or you can make a bracket with clamps,its up to you. I added a bracket to hold my tensioner in place cause my frame is too small to drill a hole in,without weakening it.
  3. Bikeguy Joe
    Jan 8, 2008
    11,529
    You need to take a link or two out of your chain.
  4. Comrade Alfonzo
    Jul 15, 2009
    143
    Thanks for the electronic instructions, I'll be pullin links tomorrow, Also Do you guys think Loctite is strong enough for the chain tensioner. And finally the motor puts out 12VDC, I need to know so I can get a capable toggle or rocker switch, possibly with a red cover.
  5. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    37
    Many times, the killswitch will be mounted on a painted handlebar and the engine won't turn off. Move the switch temporarily to bare metal and see if it works. If it works, then scrape the paint off under where the switch needs to be, then bolt it down. If that doesn't work, scrape the insulation off any part of the wire, touch it to ground with engine running. If engine dies, replace switch. If engine does NOT die, trace it back to the coil and repair connection.
    You can also run the killswitch wire to the sparkplug wire to get it to die.
    Safest way to mount the tensioner is to have someone weld a simple bracket to the frame. Then add a bolt and skateboard wheel as a tensioner.
  6. Comrade Alfonzo
    Jul 15, 2009
    143
    All right, re wired the killswitch maybe itll work. I got the chain tightened but I still think the tensioner is too loose even though it won't get any tighter. Would Loctite and ductape keep it from slipping, I still have to use a mallet to move it with just the bolts
  7. flybytaco
    flybytaco Metal Molding Madman
    Oct 17, 2009
    1,176
    yes get it where you need it and drill a hole through it and the chainstay and send a self tapper into the 2 and presto
  8. Comrade Alfonzo
    Jul 15, 2009
    143
    Thanks for the help, I think that tightening the chain will probably solve it, but I'm adding duct tape as a precaution. Also how long is it supposed to take for loctite to dry/set
  9. flybytaco
    Oct 17, 2009
    1,176
    where do you want to add the locktite? it only hardens in an air tight and its activated when compressed in a nut or in a tapped hole.. funny u mention loctite it always reminds me of an old friend from a past job he was talking and his fake tooth popped out a front one too he tried to put it back in with red locktite no joke i never laughed so hard when his tooth popped out onto the floor and then when he locktited it soooooo funny
  10. dag_29307
    dag_29307 New Member
    Jul 1, 2009
    296
    He was a redneck wasn't he? No offense to anyone.
  11. Bikeguy Joe
    Jan 8, 2008
    11,529
    Super glue would work better- for both things, and is just as bad an idea as well.
  12. Comrade Alfonzo
    Jul 15, 2009
    143
    That would be why the loctite aint workin, I just put it on the outside. Oh well Duct Tape looks better.
  13. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    Loc-Tite is for threaded fastners and such. It is not a glue to hold objects together.
    You will only be disappointed if you try to use it as such.
  14. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    I'm a central Texas country boy that will red neck a thing or two from time to time, but I can say that even a red neck would no that loctite would not work for the tooth repair, A true red neck would have built it up real nice with some JB QUICK WELD and then filed it down into a real nice purdy new tooth which would get a real nice coat of white liquid paper before a date on Saturday night.
