Snapped off a stud (eep)
Discussion in 'Motorized Bicycle General Discussion' started by Mind_Reader7, May 13, 2010.
  1. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    I snapped off a rear mounting stud. I drilled out a hole about 15mm deep with a 6mm piece to try and make the thing come loose, to no effect. So now I'm stuck with a small hole, a tiny bit larger than the stud itself. I think the rear mounting studs are a lot longer than the normal ones anyway.
    Does anyone know how I can repair it? I'm thinking maybe drilling really far in with like a 4/5mm drill piece, then buying a threading kit and making a 6mm thread. I'll then fill the hole with some kind of 2 part glue and screw the stud in.
  2. Retmachinist
    Retmachinist New Member
    Oct 21, 2008
    637
    Just drill it and tap both rear holes for 8mm. Then you won't have it happen again. That is the first thing I do to all my motors when I take them out of the box.
    John
  3. Mind_Reader7
    May 1, 2010
    393
    Oh, so just tap them out to 8mm threads?
    Man, hadn't even thought of that. Tyvm :D
  4. Retmachinist
    Oct 21, 2008
    637
    You will have to use the Tap drill for an 8 mm thread. A 17/64 will work.
    John
  5. Retmachinist
    Oct 21, 2008
    637
    Or I guess in Australia you would say a 6.7 mm drill.
    John
  6. Mind_Reader7
    May 1, 2010
    393
