Slow??
Discussion in 'Motorized Bicycle General Discussion' started by Kinskeys, Dec 9, 2010.
  1. Kinskeys
    Kinskeys New Member
    Jul 13, 2010
    33
    Yesterday my bike was doing fine, today I took it for a ride and it won't go over 18MPH, anyone have a solution?
  2. Hammond Egger
    Hammond Egger New Member
    Oct 23, 2010
    270
    How fast did it go yesterday?
  3. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    Check for air leaks maybe
  4. Elitefr
    Elitefr New Member
    Sep 12, 2010
    22
    Happened to me today too. If you're using a CNS carb try messing with the air/fuel screw, worked fine for me
  5. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Were you going up hill or down yesterday? Sorry, Just being silly.
    How are you checking your speed? Does the engine start easily, idle good? What fuel mix ratio are you using? New fuel mix, or has it been sitting for a while? Check all of your wiring connections. We recommend you solder those and not rely on the kit supplied plug-in style of connectors. What spark plug gap? Check your spark plug wire connections at the CDI and the plug boot. Let us know if any of these suggestions help.
  6. Kinskeys
    Kinskeys New Member
    Jul 13, 2010
    33
    Thanks guys, but I figure it out, exhaust leak & loose choke nut
  7. scotto-
    Jun 3, 2010
    6,530
    6
    Neither of those two things should slow you down that much, unless you choke was closing on you.
  8. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    It happens. I had to rideo ne handed holding my choke down lol.
  9. WildAlaskan
    WildAlaskan New Member
    Sep 30, 2010
    581
    i took my choke off completly cause it vibrated up and slowed me down
    i dont have a primer either so colt starts are harder but not unmanigable
  10. thine82
    thine82 New Member
    Nov 26, 2010
    115
