Side pull calliper brakes?
Discussion in 'Motorized Cruiser Bicycles' started by gobigkahuna, May 4, 2011.
  1. gobigkahuna
    gobigkahuna New Member
    Apr 25, 2011
    268
    While reading some of the build threads here, I noticed that when a bike only has a coaster break, it's usually recommended that they retrofit a center pull v-brake (which because most cruisers don't have the proper threaded posts, a special plate has to be added). I remember back when I was younger that most of my bikes had side pull calliper brakes, and when I did a quick search I found side pull calliper brake kits for sale. As I recall, to mount them all you need is a hole on the frames centerline above the wheel which most cruisers already have for mounting fenders. Why not use these instead?
  2. 2door
    2door Moderator
    Staff Member
    16,304
    29
    As long as the mechanical parts line up, there is no reason you can't use the hole in the bottom of the fork to mount the brakes.
    I realize that mounting disc brakes can involve some custom work/welding but if you have the tools and skill, disc brakes are far superior to the rim type friction brakes. Whichever you decide on, the addition of a brake on the front wheel is highly suggested.
  3. ferball
    ferball New Member
    Apr 8, 2010
    599
    V Brakes and cantilever brakes just offer better stopping power getting a mechanical advantage with the different pivot point.
    Bicycle Brake Basics
    I use the side pull caliper when ever I have to retro fit because like you pointed out they are way easier to install. I may have to squeeze a bit harder to stop but I am a big guy and can handle it.
  4. Elmo
    Elmo New Member
    Sep 3, 2009
    749
    If all you can do is use the caliper brakes use them. A caliper brake on your front wheel will give you a whole lot more stopping power than a coaster brake alone. I do not know about the current crop of cruisers but a lot of older frames also had a mount for them on the rear also. if yours doesn't it is a simple matter to weld or braze one on. This page has one, called a brake bridge. Braze ons
  5. thatsdax
    thatsdax Member
    Feb 22, 2008
    869
    I agree. Anything for a front brake is a plus and a must !! Being able to stop on a dime is the ideal, but if you can only stop on a dollar bill, take it !!
  6. gobigkahuna
    Apr 25, 2011
    268
    Thanks. My next question is, where can I buy them? I've been searching, and so far what I've found are mostly to replace the brakes on skinny tire road bikes. What I'll be looking for are brakes for 26" x 2.125" tired wheels.
  7. Elmo
    Elmo New Member
    Sep 3, 2009
    749
    Check with your local bike shop.
  8. steampunk
    steampunk New Member
    Mar 10, 2011
    438
  9. gobigkahuna
    Apr 25, 2011
    268
    @steampunk - Those are perfect, thanks!
  10. steampunk
    Mar 10, 2011
    438
    no problem...happy motoring
  11. flatblack
    flatblack New Member
    May 22, 2011
    374
    I ordered the side pull brake kit from Pirates. Calipers didn't reach the rim on my Cranny. I ovaled out the hole in the fork, elongated the adjustment area on the brakes caliper slots and made sure the wheel was as far up in the dropouts as possible to no avail. Still grabbed my tire. Not good. Moved it to the back and flipped it under the existing fender mount cross bar. It's better than just the coaster brake...
  12. gobigkahuna
    Apr 25, 2011
    268
    I forgot all about this thread... I bought the side caliper brakes recommended earlier in this thread and they worked perfectly on my Genisis Onyx 29er. :)
