Should it idle?
Discussion in 'Motorized Bicycle General Discussion' started by maxsideburn, Jul 16, 2011.
  1. maxsideburn
    maxsideburn New Member
    Dec 7, 2009
    103
    On my MB, as soon as I disengage the clutch the motor dies. Should it remain running or is that how it's supposed to be?
  2. droc089
    droc089 New Member
    Jun 25, 2011
    118
    Does it die right when you first try to start the bike or is it after it's been running?
  3. 2door
    2door Moderator
    Staff Member
    16,310
    Tell us what engine/carburetor you have. It would help us help you.
  4. maxsideburn
    Dec 7, 2009
    103
    BGF 2-stroke kit
    It runs and drives fine, what am asking is "Should the motor die instantly when I disengage the clutch? Or should it keep running until I hit the kill switch?"
    It cranks right up and runs like a top when I drop the clutch....but if I clutch in to come to a stop the motor dies the instant the clutch handle is squeezed and the clutch disengages.
  5. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    Me thinks you need to screw in the idle adjust screw a little.
  6. maxsideburn
    Dec 7, 2009
    103
    so it SHOULD remain idling when I disengage the clutch? for instance, if I start it up, lock the clutch lever into the disengaged position, and park it using the kickstand and walk away...it should stay running?
    right now it dies the second you squeeze the clutch lever in.
  7. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    Yup, it should idle with the clutch pulled in.
    If the idle screw is set wrong it will die, just like you have now.
  8. 2door
    2door Moderator
    Staff Member
    16,310
    Still don't know which carburetor you have but it should have an idle speed adjustment. Typically you screw the idle speed adjustment in to increase idle speed and out to decrease it. In being turned clockwise and out is counter clockwise.
  9. Allen_Wrench
    Feb 6, 2010
    2,787
    How's your choke lever set also?
  10. maxsideburn
    Dec 7, 2009
    103
    I always just leave the choke off. I know you're supposed to use it to help get the bike started...but when it's on I seem to have a harder time getting it started so I don't bother with it. I leave it in the "down" position.
  11. BeaverRat
    BeaverRat New Member
    Jun 27, 2011
    147
    Your symptoms sound pretty similar to mine when I was getting a massive air leak into the cyllinder.
  12. maxsideburn
    Dec 7, 2009
    103
    idles fine now.
    as it turns out the idle screw was pretty much all the way out from the factory. I had to tighten it 10 turns and now it idles. thanks guys.
