scooter drum brake
Discussion in 'Motorized Bicycle General Discussion' started by john_the_great, Jan 5, 2010.
  1. john_the_great
    john_the_great New Member
    Oct 24, 2009
    191
    Has anyone ever installed one of these on there bikes? If so, how and where did ya get it?
    [​IMG]
  2. 2door
    2door Moderator
    Staff Member
    16,308
    30
    John,
    I can't help you much with where it came from or how to install one on a bicycle wheel but I'll vouch for how well it works. There's one on the front wheel of my trike, 12" scooter style wheel, and that little guy has some stopping power. The rear coaster brake went out and I rode the trike around as a plant bike for a long time and many miles with only that small band brake on the front wheel. It shows little signs of wear and still grabs tight. I'll examine it a little closer tomorrow when I'm back to work and see if I can suggest a way that it could be adapted to a spoked bike wheel. By the way, if you don't know where to find one, where did you get the picture? Curious.
  3. bairdco
    Aug 18, 2009
    6,376
    37
  4. aero07
    aero07 New Member
    Oct 12, 2009
    45
  5. john_the_great
    Oct 24, 2009
    191
    I know i can get the one in the picture from partsforscooters I was just curious if they made one fer bicycles or how someone converted one of these scooter ones to there bikes. The Spooky tooth rim is definitely cool, but I have a nexus 3-speed wheel on the way and can't use another rim.
  6. bairdco
    Aug 18, 2009
    6,376
    37
  7. john_the_great
    Oct 24, 2009
    191
    It is a coaster brake hub but I have a sick bikes shift kit I am currently installing so the free-wheel would prevent me from peddling backwards and engaging the coaster brake.
  8. turkman
    turkman Member
    Nov 12, 2009
    221
    this is what I've been rolling around in my head too ,I'll check it out and get back to you Later Bob
  9. Tad Bit Tipsy
    Tad Bit Tipsy New Member
    Jan 2, 2010
    478
    From what I've seen this is bolted onto a disc brake 6-hole hub. That's how spooky tooth does their HD wheel. The inner brake hub is bolted to their sprocket adapter/sprocket with either two or more of the screws(depends on the mm size). Picts included.
    Also you can get different sizes here...
    90mm Large Band Brake for 2-Stroke Bike Electric Scooter Brake (4 1/2in)
  10. tyrslider
    tyrslider New Member
    Sep 26, 2008
    958
    The roller brake shimano makes is completely different. These come on Grubee hubs as previously stated. the drum threads onto right hand threads and the band is shimmed away and anchored like a coaster. You might be able to run it on a flip flop hub w/ your shift kit. I'll check for you tomorrow I have a flip flop and one of those brakes. I think they are the same size thread. Also you would need to change the axle and over locknut distance on the hub. The spooky tooth hd wheel is a Grubee hub, The sprocket adapter screws on a left hand thread so it tightens when you ride and the brake onto a right hand thread so it tightens when you brake!
