schwinn frame help needed
Discussion in 'Motorized Bicycle Welding, Fabrication and Paintin' started by Big Bill, Apr 19, 2012.
  1. Big Bill
    Big Bill New Member
    Jun 3, 2011
    117
    Hi All
    I picked up an old Schwinn frame that I would love to use,and I have a
    few questions .
    1. Will it be stong enouth to handle a 99 cc preditor?
    2. I have a 1 1/8" treadless fork that I would like to use, is there an adapter
    you can buy or do you modify your 1 1/8" head set, it looks like I would need to remove about .060 off the ID of my old head set.
    3. I will need to spread the rear drop outs out about 1 1/8" . Do you heat
    the frame to bed it or pull it cold? Are there any tricks ?
    Thanks for the help Bill
  2. halfevil333
    halfevil333 New Member
    May 18, 2010
    307
    Have you checked the year? You can do this by copying the serial# from the bottom bracket, and then googling it, I believe Sheldon Brown wrote a whole article on this, usually the letter, or first number denotes year, then mo.....
    Point is, IS IT A CHICAGO SCHWINN, REAL STEEL OR CHINA BUNK?
    EITHER WAY I WOULD SUGGEST GUSSETS AND OTHER STRUCTURAL SUPPORTS WELDED IN.
    the stretching can be done cold with a piece of " 3/8" all thread" the appropriate nuts and a couple washers.
    Put the nuts to the center of the all thread with the washers to the outside. Slip this into the rear dropouts, slide washers against dropouts, bring nuts to washers (he he) finger tight.
    This is where I usually make up some cockamaimy scheme to measure and keep this all straight, HOWEVER, if you do an even amount of turns on either nut, it SHOULD keep spreading the frame evenly.
    You will have to bend out aprox' 15-30* beyond your mark to account for "spring-back" or the "memory" of the steel.
    ...hope this helps, keep us posted, pm me if you have questions or contact one of the moderators....they're like Albert Bikestein's all knowing, and Yoda like.
  3. Big Bill
    Big Bill New Member
    Jun 3, 2011
    117
    The frame is a 1975 , I had my daughter pickit up in California for off Craigs list for $20.00 .
    I will be adding gussets to the frame and the rear drop outs will be changed
    so you can silde the tire on from the rear. I will make a fixture to hold the frame so I can measure as I bend.
    I was thinking of removing alittle material from inside the head tube and
    alittle off the Od of the headset do you think this will work?
    Thanks Bill
  4. flmotorbikes
    flmotorbikes New Member
    Mar 23, 2012
    174
    Sandblasting before painting would help
  5. Ibedayank
    Ibedayank New Member
    Oct 29, 2011
    1,171
    You do not want to weaken these areas!!! There are sources for 1inch stem forks if you need a smaller stem
  6. Big Bill
    Big Bill New Member
    Jun 3, 2011
    117
    1" fork here I come.
    Thanks Bill
  7. Adama
    Adama New Member
    Feb 5, 2011
    10
    Take a look at The Retor Ryder Headset by Genuine Bicycle Products. It allows you to use a 1 1/8” non-tapered fork in an older bike that uses a 1” threaded headset like the older Schwinn’s. You will have to check your head tube as it will only work if the inside diameter is 30mm. I ordered one and install a Suntour XCR suspension fork onto an old Schwinn Typhoon last week that I’m building.
  8. chainmaker
    chainmaker New Member
    Jan 19, 2010
    2,597
    hows this coming along
  9. headtrama
    headtrama New Member
    Jul 8, 2010
    889
    You can put a 1 1/8 th fork on a old schwinn. I did it mixing head sets and bearings and modifying the cups . Google your question and you will find some good info on it .
  10. tommyboy1442
    tommyboy1442 Member
    Nov 25, 2009
    239
    whats up bill, tom here from chicago. in my opinion, 1 yes that frame will hold up, especially if most of the china ones are, 2. anything is possible, but your looking at some serious modifcations to make a bigger fork work. id just go with a 1 " threaded, and 3 why do u need to spread the dropouts? im gueussing your running a geared wheel on a single speed, i wouldnt recomend spreading the frame that much. youll stress the frame and then it wont be holding up too long with a motor. if anything your better off cutting and rewelding. thats just my opinion, however listen to these guys cause i learn things i never knew all the time on here. have a great day by the way.....
  11. headtrama
    Jul 8, 2010
    889
    The frame should be fine with that motor . I gusset all my frames and weld the two bars to the seat post tube top and bottom . I spread all my frames apart cold never had a issue doing it this way .My last Schwinn i built has a 5 horse briggs in it , that motor is a little bigger size wise then what you plan on putting in yours.
