Schwinn Computer Question
Discussion in 'Motorized Bicycle General Discussion' started by crzyolphart, Dec 13, 2009.
  1. crzyolphart
    crzyolphart New Member
    Aug 12, 2009
    44
    Well; I've brought my bike in for winter & I'm doing a BUNCH of "mods".
    I've added a trunk; a remote choke control, a clutch cable end guard,
    and a Schwinn speedo/trip computer. My question is for anyone with experience with these computers. Has anyone successfully "shortened'
    the signal wire between the mounting bracket and transmitter? Are there any adverse effects? (calibration problems, etc.) Thanks in advance for any help. (sorry about the crappy bike pic.) :(
    Rob :<{)
    #1 crzyolphart, Dec 13, 2009
  2. wjliebhauser
    wjliebhauser New Member
    Oct 24, 2009
    51
    I hate to be negative, but I tried two different electronic computers (albeit neither was a Schwinn) and neither would work while the engine was on. Too much field interference from the magneto. I toyed with the idea of trying to work up some shielding, but I think it would require totally insulating/isolating the motor from the bike frame, but the mag is strong enough, I am not sure the insulation would have cured the field effect, as the trip computer/speedo works on very small current anyway. One of the shielding fixes I considered was using sielded CAT5 cable from the sensor to the computer, and fabing an insulated steel or aluminium 'box' in which to mount the computer to try to shield it from the mag; it might work, but a whole lot of effort. I just found an old mechanical speedo on e-bay for $10.
    Having said that, I've seen some posts that some folks have made the electronic ones work, so maybe you'll be ok. As to your actual question, long as you do a quality splice of the sensor feed wire (I suggest soldering the re-splice and applying either heat-shrink tube or silicone for a good seal) the shorter wire should actually be better, not worse (less line loss).
    Good luck!
  3. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,501
    50
    I have had more then a few of those and only had a problem with one. Think it was just the batt but never messed with it. Had them on both 4 and 2 strokes. Don't see why it would not work, shortening the cable but dunno fo-shore
    Really like your "trunk" Gonna get around to getting one of these some day. Would work as a cooler too.
    ActionPacker® Cargo Box / Bin | Rubbermaid
    #3 Dan, Dec 13, 2009
  4. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    my $10 walmart schwinn speedo acts up and resets while starting,but after the engine is running it works.
    when i had a basket on the front of my bike(i dont have a basket in front now) i mounted the speedo on the front edge of the basket and ran the wire up the side of the basket which is 1 foot from the hadle bars and the speedo worked perfect. so theres your answer,keep the speedo and wire away from the handle bars,cdi any other cables or wires. im working on a long plastic bracket to get the speedo and wire farther from the bikes handle bars and im sure it will work better.
  5. Finfan
    Finfan New Member
    Aug 29, 2008
    871
    I had a Blackburn Delphi speedo that was always resetting and locking up. I changed it out with a Cateye Velo that I have had no problems with at all. Never tried shortening the wire on either of them.
  6. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Keep in mind that the throttle and clutch cable and kill button wires are connected to the engine. Try keeping the speedometer as far from those parts as possible. Also try mounting the CDI on the seat tube instead of the down tube. Anything you can do to keep the speedometer head as far from the CDI as possible will help. The electronic interference comes from the CDI and high voltage lead (spark plug wire), not the magneto. Some people have had luck using resistance ignition wire instead of the copper core wire that comes with most kits. The solid core wire is better for the engine but the resistance wire, or TVRS wire will perform okay and might reduce the RF interference enough for your speedo to function properly. As far as shortening the leads, why do you need to do that? Simply coil the extra wire and use a nylon tie-wrap to secure it.
    #6 2door, Dec 13, 2009
  7. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    All my bikes and all the bikes I have built I use the Schwinn speedo and have never had a problem with any of them. But no I have never tried to cut the wires to shorten them.
  8. wjliebhauser
    Oct 24, 2009
    51
    Sounds like Schwinn and some of the better ones may be shielded internally and are better quality, as they are working for many folks. The ones I had were Hong Kong cheapies (you get what you pay for!). I personally think the problem is the field effect from the magneto, as the electronic speedos work by sensing a small permanent magnet passing a tiny detector coil sensor. But whether it is high voltage pulses from the ignition or magneto field effect...the fixes are the same! Isolate and shield.
  9. rkorson4209
    rkorson4209 New Member
    Oct 10, 2009
    251
    i HAVE TRIED 4 DIFF SCHWINN ONES FROM WA MART, AND NONE WOWKED FOR ME.
  10. doubledice
    doubledice New Member
    Nov 6, 2009
    130
    Mine went through the washer and dryer once and still worked lol it scared me at first
    laff
  11. DonnnN
    DonnnN New Member
    Jun 4, 2009
    198
    My cateye velo 5 is rly good.. :)
  12. upsrogue
    upsrogue New Member
    Jul 14, 2009
    23
    I had all kinds of problems with the $10 Schwinn computer and just gave up, then I paid $30 for a Cateye Velo5 computer and all the problems where gone, I did'nt worry about where I ran the wire just put it on.
    I was about to take the Schwinn computer back to Walmart and tell them it was broke and get my hard earned $10 back but then as a last chance put it on my pedal bike and it works great there not a hitch, so I guess I'll keep it and when I build another motor bike I will spend $20 more and the computer problem will be fixed.
    And don't try and shorten it just use string ties and hide it.
  13. upsrogue
    upsrogue New Member
    Jul 14, 2009
    23
    Oh and the Cateye computer will tell you your "calorie consumption" even though you did'nt even pedal the bike, you just sat there the whole time, a nice plus Haaa.
  14. Mrakulous
    Mrakulous New Member
    Mar 9, 2009
    57
    I purchased a $15 Bell speedo from the bx. I only put a couple miles on it before my rear wheel failed. But I have not had any problems. Yet.
  15. crzyolphart
    Aug 12, 2009
    44
    Well, Thanks to all who replied. I've decided, Rather than chance ruining what seems to be a perfectly operating Computer/speedo; I'm just going to bundle up the excess wire & wire-tie it in an inconspicuous area. My
    whole issue to begin with was purely aesthetics. I HATE to se loose "stuff" hanging all over my machinery. (what can I say; I'm rather OCD)
    Again,
    Thanks all!
    Robzpt
    #15 crzyolphart, Dec 15, 2009
