SBP expansion chamber leaking from all seals
Discussion in 'Motorized Bicycle General Discussion' started by geoldr, Oct 15, 2011.
  1. geoldr
    geoldr New Member
    Jun 19, 2011
    260
    Hey guys, so after installing my expansion chamber, I had to take it off once. After putting it back on, I used those black silicone things they provide, and I also used high temp sealant that I painted around it to seal. Now though, its leaking from 2 out of the 3 seals! It blew through the liquid stuff. I don't know how to fix this. I don't have a welder so I cant weld the thing. I can provide pictures tomorrow if necessary
  2. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    37
    You DID tighten up the clamps, yes?
  3. richirich
    richirich New Member
    Aug 16, 2011
    297
    i used a mapp gas torch and soldering rod to seal the copper fittings.
  4. geoldr
    geoldr New Member
    Jun 19, 2011
    260
    The exhaust came with 3 clamps. I used 2 on the big J-pipe to expansion chamber. And the last one on one of the small seals. Ill get more from the store and use them. I was actually thinking that.
    richrich, I only have a propane torch
  5. richirich
    Aug 16, 2011
    297
    propane would work , it just takes alittle longer to heat it up
