'Rust' textured powder coat.
Discussion in 'Motorized Rat Rods' started by KCvale, Dec 4, 2015.
  1. KCvale
    KCvale Active Member
    Feb 28, 2010
    3,878
    14
    I have been looking over what my local powder coating place has available and couldn't believe the colors, 'glosses' and now texture choices!
    Here is their available baked on powder pallets.
    http://glendalepowdercoating.com/fig/colors/PowderBrochure (Large).jpg
    I have a couple of new Grubee Skyhawk GT2A-150 frames coming, and as I looked through the choices I couldn't help but think of Rat Rods...
    The very bottom right color choice, 'Rust Texture Semi-Gloss' hehe!
    [​IMG][​IMG]
    It reminds me of pre-washed jeans, get it new but looking old and used.
    If you want to use new stuff but make it look like it's old (or not worth stealing) this might be just the thing for you Rat Rod guys.
    #1 KCvale, Dec 4, 2015
  2. 2door
    2door Moderator
    Staff Member
    16,301
    24
    That would sure beat the bare steel/salt water treatment. Not only would it give the RR look but the metal would be protected.
    Thanks for sharing, KC.
  3. KCvale
    Feb 28, 2010
    3,878
    14
    Sure, had to share that, I'll know a little more about all these new coatings by next weekend as I have 2 new bare Aluminum GT2-150 frames to coat.
    I don't know what the market for Rat Rods are here but it might be fun make a kick butt fat tire shifter ala Rat Fink style with gizmos, extra long suicide shifter, you know what I mean.
    Another color/texture I noticed was rock textures like Granite, how about a Fred Flintstone MB?
  4. 2door
    2door Moderator
    Staff Member
    16,301
    24
    For me there is something very appealing about the Rat Rod look. There are a lot of guys in the street rod community who poo-poo on the 'rusted beater' look but if done right, by that I mean proper brakes, steering and attention to safety and reliability, the rat rods are more indicative of what real hot rods looked like back when they first appeared on the roads of America. Built by returning G.Is home from the war and without big bucks to spend, they constructed what they could afford. R-Rs certainly are more accurate than what you see at car shows and hot rod gatherings today.
    It's the same for bikes. The Rat Rod forum is filled with awsome looking builds inspired by the traditional 'look' of early street machines.
    Go for the fat tire R-R, KC, and show us what it comes out like.
  5. WECSOG
    WECSOG Member
    Nov 10, 2014
    118
    I like rat rods. Real deal rat rods. To me, something that has had lots of money spent on making it look like a rat rod is a poser. A rat rod should actually be a junkyard refugee; not just be made to look like one. But that's just my opinion.
    I'm actually not opposed to a powdercoat finish like this, as long as it is a practical finish and not too expensive. I would probably consider it for something like my '70s Westport (if I didn't already have more naturally "distressed" bikes) as long as it cost less than $100; but I would much rather spend the same money on a rusty prewar Elgin frame and hit it with some Rustoleum ruddy primer from a rattle can. Now that's rat!
    drn2
  6. racie35
    racie35 Active Member
    Nov 17, 2012
    1,699
    It's a look I try to avoid.
  7. KCvale
    Feb 28, 2010
    3,878
    14
    As do I, but it's more than that, if I'm going to build a bike I am not going to start with a bunch of used discarded ****.
    Anyway, just thought I'd share that 'poser' powder coat rust color.
    It was $150 to PC and seal the frame and few other parts and that stuff is double tough, like metal pool furniture, it will never be a real rat rod.
  8. bairdco
    Aug 18, 2009
    6,322
    If you want to go the cheap route, mix hydrogen peroxide and salt in a spray bottle, spray it on raw steel and it'll rust before your eyes.
    Wash that off and clear coat it.
  9. MEASURE TWICE
    MEASURE TWICE Active Member
    Jul 13, 2010
    2,057
    11
    If you have surface rust, how do you tell if it is only on the surface? Hitting it lightly with a hammer?
    My bike frame has been for extended period without paint as I am still wanting to weld modifications to it. I've never seen and pitting only patina color. If I sand the rust off, then I've seen metal shine always with very little effort.
    I've seen engine crankcase bottom made of pot metal rust and take large areas of metal that looked as pitted. I have had no leaks and have for years left it also unpainted. When it pitted I think it was when it was sitting in wet mud for a long time.
    It or the bike frame are seeming stable, so I may do clear coat on the frame and if there is something that can act like a clear anodyne for the engine. I know powder coat for aluminum works really great, but I don't if there would be adverse effect on engine with the oven I've used at a membership shop you have access to tools like that.
    Does anyone know if powder coat clear or anodyne work on oxidized surfaces as I have remembered using an extensive cleaning process to prep? Rattle can clear coat I can test a small area and just see what happens.
    MT
    #9 MEASURE TWICE, Dec 25, 2015
  10. bairdco
    Aug 18, 2009
    6,322
    I use rustoleum automotive clear coat in a spray can from home depot. Hands down, the best clear I've found. Gas resistant, and a hard surface that resists chipping, fading, whatever.
    Surface rust means no pitting, no loss of base metal, no serious damage to the steel underneath.
    If the rust is eating away at the integrity of the metal, that's bad. If it's just sitting on top discoloring it, it's got a long way to go before serious damage occurs.
    Clear coating will preserve the patina, and keep it from getting worse.
    I mean, eventually the rust underneath will do some damage, but you'll probably be dead, or the bike forgotten before that happens.
  11. KCvale
    Feb 28, 2010
    3,878
    14
    I like shiny and buttoned up tight.
    The kind of machine you keep clean and shiny.
    A machine that turns heads ;-}
  12. WECSOG
    WECSOG Member
    Nov 10, 2014
    118
    Interesting comments, considering that they are in the "Motorized Rat Rods" sub-forum. laff
  13. langolier
    langolier Member
    Jul 6, 2015
    57
    I love Powder coating it's tough as nails. Only my opinion but if you get a powder coat that looks rustic I think it would be too "uniform" for a true rat rod look, Things just don't rust in a uniform way. It would be interesting to get a sample piece to see if one could transform or change the look by using sand paper or steel wool.
    #13 langolier, Jan 8, 2016
  14. KCvale
    Feb 28, 2010
    3,878
    14
    Again, I only came in this forum area to share a new powder coat that looks 'rustic' for those looking for the 'look' on something brand new is all.
    Jezz, I'm sorry I shared, I didn't know in advance this forum was devoted exclusively to building EXCLUSIVELY on old rusted out bikes!
    Rust and Rig on guys, sorry I invaded your redneck space.
    Jezzz...
  15. langolier
    langolier Member
    Jul 6, 2015
    57
    Was only food for thought on my part KC, never built a rat rod or attempted a rustic finish myself. So my 2 cents worth is probably only worth just that. Not meant to flame anyone.
  16. WECSOG
    WECSOG Member
    Nov 10, 2014
    118
    Thanks for the heads-up. Like I said in an earlier post, it is an interesting finish if it's not too expensive.
    Certainly no reason to get all huffy (laff) and start insulting us. We get it; you don't like rat rods. We do. Sorry if that offends your sensibilities.
  17. 2door
    2door Moderator
    Staff Member
    16,301
    24
    :) You guys are killin' me. You're killin' me!
    Wouldn't it be fun if we all could sit down, face to face, and have these same discussions? I'll bet there would be some good laughs.
  18. WECSOG
    WECSOG Member
    Nov 10, 2014
    118
    Yep, it would! But hey, I'm not mad or anything. The rofl thing is real. We all like what we like, and there's not accounting for taste; poor or otherwise!
  19. langolier
    langolier Member
    Jul 6, 2015
    57
    Mmmmm ...... Maybe I will have to check out that Midwest Bike rally on June 11th after all...... I could buy a round of drinks that would give me a license to talk stupid. (^)
  20. 2door
    2door Moderator
    Staff Member
    16,301
    24
    We'd like to have you, Langolier. Any fan of Steven King is a friend of mine.
    The June cruise will be a good one. And it's centrally located so lots of guys can make it. I wish every member here could come. What a hoot that would be.
