Running for the 1st time
Discussion in 'Motorized Bicycle General Discussion' started by Evan, Dec 20, 2009.
  1. Evan
    Evan New Member
    Dec 6, 2009
    103
    Well, the time is near and I will be running my motor for the first time today. Being brand new (both me and the motor) is there anything I night want to do before firing it up? I dunno..... couple drops of oil in the chamber? "Prime" it some how? etc. I want to do it right to get the most out of my new found hobby. Everyone here has been so helpful and I hope that I'm not (again) asking something that has already been covered. Thanks for all the help.
    Evan dnut
  2. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    Just mix the gas at 24:1 & fire it up!! Also, don't let it idle!! (just start riding it.)
    Cruise it around the neighborhood for a while & get it nice & warm, & then you can start riding it normally.
  3. wes
    wes New Member
    Aug 17, 2009
    207
    there is a whole thread on peoples opinion for proper break in prcedures, you might check it out, there is a primer on the left side of the carberator, it is a little plunger, push it in for a couple seconds and you will se the fuel flow down the line and into the float bowl, after that give everything a once over and i usually ride down the rode and check chain tension and roll and so on before i ever pop the clutch, take your time a be patient so that you dont miss anything, Good luck Evan, and welcome to the Forumn!!!
  4. xlite
    xlite New Member
    Jun 18, 2009
    736
    I suggest pedalling around awhile and try a few hills to make sure the chain is ok then let that clutch out.
  5. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    Thats actually very good advice!! I've been building these for so long that I rarely have trouble with the chains, (but a first time builder probably will!!!)
  6. Evan
    Evan New Member
    Dec 6, 2009
    103
    Good advice. As soon as the rain lets up I'm goin out.
    E
  7. 2door
    2door Moderator
    Staff Member
    16,310
    And pedal slow and keep a close eye on the chain tensioner (if you're using one). Too mnay people want to see how fast it will go first thing and that's where they get into trouble. Easy does it for a block or so to assure that everything is working and staying where its supposed to be before twisting that throttle too much. Good luck, keep us posted on your success.
  8. xlite
    xlite New Member
    Jun 18, 2009
    736
    Personally pedaling slow is not my method. I'd rather find a problem by pedaling fast or rolling down hill than going slow with the engine running. This is specially important if, like me, you're one of the brave souls who forgo tensioners.
    I do agree about taking it easy for awhile when that engine is fired up.
  9. Evan
    Evan New Member
    Dec 6, 2009
    103
    Well I had a few issues with the chain and then the clutch. The idler was crooked to the chain no matter how i mounted it on the frame so i heated it up and bent it a bit. Then i had to mess with the clutch a bit to get it to work and not collide with the brake handle/gear shifter on the handlebars. Now it's dark (and raining) probably not the best time for my first ride. I'll have a couple hours of sunlight in the morning before I have to go to work so hopefully i'll get it going then. Not sure i'll be able to keep myself from trying again tonight but as you probably guessed i'm quite antsy. Thanks for everyones help so far. i'll keep you posted.
  10. captainrichhill
    captainrichhill New Member
    May 31, 2008
    203
    Make your first powered "flight" a short one. Maybe just around the block then let it cool down and check all the nuts and bolts before your next ride. If you ride it in "baby steps" it won't leave you stranded and pedeling home because a nut is loose on something.
  11. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Sounds like you're in good shape. The stock chain tensioner bracket does need to be twisted a bit to make the idler line up right with the chain. Another bit of advice - if you don't replace any other hardware on the engine kit, at least replace the bolts/nuts that hold the tensioner bracket to the frame. The grade 4 bolts are too soft, and the threads will strip before you get it tight enough to stay where it's supposed to stay.
    I can attest to the greatness of a dual-pull brake handle. I ran for a little while without one, and the brake handle on the left side, with the clutch handle, was completely useless. So either just depend on whatever brake you have on the right side, or get a dual-pull.
  12. Evan
    Evan New Member
    Dec 6, 2009
    103
    What exactly is a "dual pull brake"?
    Evandance1
  13. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
  14. restapukin
    restapukin New Member
    Jul 22, 2009
    112
    Not for me, brothers & sisters, i like independent control of front and rear braking too much to ever give it away. I would not feel safe with a double brake lever. What can i tell you.
    I like real good brakes that allow me to safely throw on the brakes at full strength and with good feel ... modern brake blocks that brake just as good in the wet are wonderful...
    But speaking of wet weather, it's when the rain starts that i fear two-into-one brake contraptions the most....
    call me old-fashioned
  15. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    If I have to choose between one handle pulling both brakes, and two separate handles where one is all but useless because the clutch is in the way, I'm going to choose dual pull.
