riding the clutch?
Discussion in 'Motorized Bicycle General Discussion' started by Mike Hunt, Oct 17, 2009.
  1. Mike Hunt
    Mike Hunt New Member
    Jun 9, 2009
    184
    is it bad? i do it all the time, like if im going slow in a parking lot behind some slowpoke in a car ill throttle up to match their speed and hold the clutch in until i slow down then give it more gas and so on. regular riding i throttle up all the way until i reach desired speed, hold the clutch in until i slow down slower than desired speed and repeat the process.
  2. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Riding the clutch on any vehicle is not a good thing. It increases wear and shortens the life of the clutch components. Friction and heat are generated and the clutch friction surfaces are effected. Try to avoid it to lengthen the life of the parts.
  3. Venice Motor Bikes
    Mar 20, 2008
    6,215
    25
    As long as you're not 'slipping' the clutch, they'll last a real long time!!
  4. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Paul,
    What's the difference between 'slipping' and 'riding' the clutch? Always thought they were the same thing.
  5. mechanickid
    mechanickid New Member
    Aug 7, 2008
    419
    "riding the clutch" to my knowledge comes from old car language where the clutch spring would wear out after a while, old timers are still afraid that the new springs will do this so they encourage putting your car in neutral to coast instead of holding the clutch in.
  6. Reel Adventure
    Reel Adventure New Member
    Jul 1, 2009
    73
    first, nice name. :)
    Riding the clutch is ok. If the clutch is IN or OUT it is ok. 1/2 way for extended periods of time is not good and result in wear.....mr hunt :D
  7. bandito
    bandito New Member
    May 22, 2009
    783
    Unless your racing a clutch should be used for only 2 things starting off and shifting up or down. Ive even seen a few truck drivers who didnt believe in using a clutch just speed shifting up or down, thing is they didnt own the truck and didnt have to pay to replace the gears when they failed prematurely.
    #7 bandito, Oct 18, 2009
  8. Bikeguy Joe
    Jan 8, 2008
    11,529
    Heh heh.
    I have driven everything from a VW Rabbitt to an 80,000 pound truck and several hundred thousand miles, and I almost never use the clutch.
    It's a simple matter of matching engine speed to the vehicle speed. It is actually easier on the vehicle when done right.
  9. Bikeguy Joe
    Jan 8, 2008
    11,529
    For the bikes, I generally pedal, and release the clutch, but anytime I am off the throttle I pull it in.
  10. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    note: This is very true, but some newer cars don't like it (Toyotas are... tricky). It can be done - but I'd advise learnin' it on one you don't care about lol
    Lost the throwout bearing on my ol' army jeep - drove it for almost a year by speed shiftin' and using the starter for first and reverse :D THAT I wouldn't recommend tryin' in any civilian car lol
  11. Venice Motor Bikes
    Mar 20, 2008
    6,215
    25
    Yes... thats what I'm talking about!
    I use the engine to help slow me down & pull the clutch in just before I stop, & I use the pedals to get up to speed & let the clutch out so it's not slipping & wearing out.
    My clutches (& brakes) last forever this way!!! ;)
