reverse mounting gas tank
Discussion in 'Motorized Bicycle General Discussion' started by thxcuz, Mar 22, 2015.
  1. thxcuz
    thxcuz Member
    Jul 26, 2012
    290
  2. bluegoatwoods
    bluegoatwoods New Member
    Jul 29, 2012
    1,577
    I'm not familiar with that one. But it looks like it could be pretty good. There's another tank on some vendor sites that mounts underneath a rear rack.
    And I notice one similarity between the two; out of stock.
    I suppose they'll actually be available sooner or later. But it's beginning to seem like later is the better possibility.
  3. maniac57
    Oct 8, 2011
    4,486
    I like that!
    But not enough to risk my hard earned cash with that vendor.
    Been there, done that, didn't like it.
  4. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    Nice tank but I gotta agree with maniac57 on the other part...
    the other issue with that tank is since it mounts under the top bar you could run into clearance problems if mounting in a small mountainbike frame, it should fit most larger diamond frames like most roadbikes use without clearance issues... be sure to take measurements before buying...
  5. MotorBicycleRacing
    Jul 28, 2010
    5,704
    34
    The tank is out of stock at the Berry.
    Its been out of stock for a long time just like those pineapple adapters.
    Does anyone still sell this tank?
    All the ones I saw were funky and rusty
  6. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,659
    70
    funky and rusty and dented are the way they used to come when new - might be why they are not around anymore
  7. Trey
    Trey $50 Cruiser
    Jan 17, 2013
    1,432
    The ones that are inside the rear rack look good, as do the ones behind the seat.
    Depending on what bike you've got, you could mount that peanut tank on the factory rack. I did temporarily, and liked it enough to keep it.
    Almost anything will work, Briggs and Stratton make metal cans that look possible for our application. Anythings' better than that kit tank on the top bar.
