replacement engine hardware
Discussion in 'Motorized Bicycle General Discussion' started by msrfan, Oct 4, 2010.
  1. msrfan
    msrfan Active Member
    Sep 17, 2010
    1,717
    9
    I can find plenty of socket head screws the correct diameters, pitch and length for my chinese motors, but the 10mm head diameter of the 6mm bolts are too large. I mostly looked in the McMaster--Carr catalog. I was ready to buy packs of 100 until I saw the problem. I looked for threads addressing this topic, but came of empty. Maybe some of you know a vendor that sells hardware sets. Thanks in advance for your suggestions.
  2. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
  3. msrfan
    Sep 17, 2010
    1,717
    9
    Thanks MR7
  4. bairdco
    Aug 18, 2009
    6,334
    19
    if you look in the catalog under "socket head cap screws" you can change them all out for allen heads that fit perfect.
  5. msrfan
    Sep 17, 2010
    1,717
    9
    Thanks bairdco. That's where I found them but the heads on the 6mm are 10mm diameter and won't fit the recess.
  6. bairdco
    Aug 18, 2009
    6,334
    19
    weird. i've bought them from McMaster -Carr before and they fit perfectly. i went to an actual store, though. didn't even check the diameter.
  7. msrfan
    Sep 17, 2010
    1,717
    9
    Could be my latest two BGF motors are different. I'll double check. Thanks.
  8. bairdco
    Aug 18, 2009
    6,334
    19
    yeah, my grubee GT4 and my GT5 use different bolts. i've had 3 GT4's so i stocked up on hardware.
    there's a place called McFadden-Dale Hardware in santa ana, near edinger and the 55...
    they have other socal locations, too. Anaheim, Corona...
    they have everything. i just take all the bolts with me and match them up. super cheap, too. like 10 cents a bolt.
    they also have tools, paint, heat shrink, wire, plumbing stuff,...
    it's like the disneyland of hardware stores, but cheaper.
  9. msrfan
    Sep 17, 2010
    1,717
    9
    I forgot about McFaddendale. I've been there a few times. I just ordered 100 each of 5 different sizes from McMaster-Carr to be delivered at work tomorrow. I'll have enough for a few motors. I can turn the heads down on a lathe if I have to. Thanks for the input.
  10. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    A couple of rotations of the socket head screws head on the grinding wheel of a bench grinder or hand held 4" - 4 1/2" disc grinder and the size will be just right, this is how I fitted all of mine on my engines, some unground bolts fit fine and others were too big, the grinding is just slight and they will work great, if you want them black or silver again grind them, and then spray them with a shot of brake cleaner then just shoot a coat of the color spray paint you wish and BAM.......!
    I didn't paint mine because the ground part is hidden after they are installed, but one could if they wish of coarse.
  11. msrfan
    Sep 17, 2010
    1,717
    9
    Okay. Good info. Thanks.
  12. bairdco
    Aug 18, 2009
    6,334
    19
    if you do need to grind them down a bit, you should repaint them. they rust really easy. probably not enough to seize up, but enough to look ugly. who wants brown bolts?
  13. msrfan
    Sep 17, 2010
    1,717
    9
    Yeah, I just got my bolt order in and tried one and I will have to use my belt sander on a few. Semi-flat black should get them back to stock looking. Thanks.
  14. mapbike
    Mar 14, 2010
    5,380
    good deal hope they all work out good for ya......
