removing black finish from shimano hubs
Discussion in 'Motorized Bicycle Welding, Fabrication and Paintin' started by chicagoschwinn5, Jan 30, 2012.
  1. chicagoschwinn5
    chicagoschwinn5 New Member
    Sep 14, 2009
    13
    I finally figured out the best way to remove the finish from a black aluminum hub. I had tried everything from aviation stripper,paint remover and could not get any finish off then tried something new. I found out is not powder coat it, is anadized. the best remover is easy off oven cleaner it instantly removes the finish be very careful and rinse the hub every few minutes with clean water and re-dance1apply, also use a green scoring pad and wear gloves. I hope this helps the guys who want a bright finish.
  2. 2door
    2door Moderator
    Staff Member
    16,301
    26
  3. chicagoschwinn5
    Sep 14, 2009
    13
    I wish I new about that before I did everything else. Thanks
  4. BigBlue
    BigBlue New Member
    Nov 29, 2011
    781
