Regular, Super, or Premium Fuel? Thoughts?
Discussion in 'Motorized Bicycle General Discussion' started by Zoomie, Dec 11, 2010.
  1. Zoomie
    Zoomie New Member
    Dec 8, 2010
    11
    I'm pleased to announce that my motorized bike project is almost done.
    Almost time to go to the corner station and fill up a can of gas.
    It's got me wondering whether the grade (octane) of gas matters in the least. Since I'll be getting less than a gallon at a time I guess money is no object and my first knee jerk reaction is to go for premium ;-)
    Any thoughts and/or (better) observations?​
    (2-cycle 66cc)
    #1 Zoomie, Dec 11, 2010
  2. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
  3. Zoomie
    Zoomie New Member
    Dec 8, 2010
    11
  4. Hammond Egger
    Hammond Egger New Member
    Oct 23, 2010
    270
    I figure if 87 is good enough for my Honda Civic it's good enough for my Grubee Skyhawk.
  5. scotto-
    Jun 3, 2010
    6,530
    6
    I prefer nitro-methane in my huasheng....it goes purty fast ya! High octane fuel is all I use in small engines, 2 or 4-stroke. 89-91 octane unless the compression is upwards of 15:1, then it's av-gas or 105-115 octane will do.
  6. bairdco
    Aug 18, 2009
    6,350
    25
    i use chevron supreme (91 octane.) i dunno if it helps (i know it doesn't hurt,) but at 100 mpg, it's not like i have to pinch pennies.
  7. breno
    breno New Member
    Aug 19, 2010
    411
    i'm a sucker for the high octane fuel 98RON everytime only from BP servos too
  8. WildAlaskan
    WildAlaskan New Member
    Sep 30, 2010
    581
    but no i dont care about your choice of feul ut **** bp just like they our enviroment
    those basterds are using out of date machinery that has given them problems in recent years resulting in small oil spills here and massive ones elsewhere (u know where) but rather than upgrade to proper machinery or pay for the right equpment they found it was cheaper to pay a fine and fix the problem after it has spilled oil all over tundra or if it has happend in the ocean just hide it with chemicls that are more toxic than oil itself up here bp and all the other oil companies make enough money in the first month to cover operating costs for the entire year so they have 11 months of profit its just to easy to pay a fine instead of fixing the problem
    at least thats how it is hear
    #8 WildAlaskan, Dec 12, 2010
  9. WildAlaskan
    Sep 30, 2010
    581
    ohh i use regular but i think ill start buying my own gas instead of taking my dads so ill go with premium
  10. breno
    breno New Member
    Aug 19, 2010
    411
    I dunno about that I am running a 6cyl. twin cam 4litre turbo on 17psi (reason of loss of license LOL)
    If i were to run my car on shell, mobil and even worse caltex I can hear the motor pinging sounds like a ball hammer going nuts on the head of my motor. Yooouch!!
    Shell isnt too bad but I had a bad experience with water in the fuel not saying that there fuel is bad just probly a dodgey servo. This is what has worked for me anyway by no means am I saying it is gospel. Peace
  11. breno
    breno New Member
    Aug 19, 2010
    411
  12. Goat Herder
    Apr 28, 2008
    6,251
    I think if the guy behind you was filling up on lower octane stuff before you at the pump. Then by the time you fill up that Little one gallon container. All ya did was clear the pump and the hose of the low octane stufflafflafflaff
  13. Goat Herder
    Apr 28, 2008
    6,251
  14. breno
    breno New Member
    Aug 19, 2010
    411
    seperate pump lines for the different grades of fuel.. cheers anyways though
  15. biknut
    biknut Active Member
    Sep 28, 2010
    6,365
    I started out running super in my 48cc China Girl. After a few tanks I decided to try regular. I can't tell much difference but I guess it runs better on the regular.
    I don't think these motors have very high compression so why would they need high octane gas? I'm thinking about 8:1
  16. solokumba
    solokumba New Member
    Nov 24, 2010
    215
    The highest costing one they have. At 1/2 gallon a tank full, I can afford it.
  17. Goat Herder
    Apr 28, 2008
    6,251
    I am still picturing at least a half quart here but then again I am assuming?
  18. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    It's a well proven fact that an engine designed for low octane gas will loose some power using high octane.
    High octane only means the gas burns slower and the engine needs advanced timing and higher compression to get any advantage.from more octane.
    You can even cause pre mature damage to the engine because the fuel is still burning during exhaust stroke, making valves and or exhaust ports hotter, also a waste of fuel to have it exit the engine before applying most of it's energy to the piston.
    This has been proven by dyno tests on Ducati bikes, I know that for sure.
    Wayne Z
  19. 2door
    2door Moderator
    Staff Member
    16,301
    26
    By using the high priced stuff the only ones realizing a benefit is the oil company that sold it to you. There is absolutely no benefit to using high priced/octane fuel in a single cylinder low compression, 2 stroke engine designed to run on almost anything that will burn. Stop wasting your money and use the cheapest fuel you can get at the pump. Speed and power increases are only in your head, not your engine's.
  20. Lance Portnoff
    Lance Portnoff New Member
    Mar 22, 2010
    351
    premium all the way !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
