Recommend a Reliable Kit for towing a Trailer in Yucatan this Winter?
Discussion in 'Motorized Bicycle General Discussion' started by lapo, Dec 11, 2012.
  1. lapo
    lapo New Member
    Oct 12, 2009
    Hi All, new to the forum here and this is my first post. Ive yet to own a motorized bike but have been dreaming of it for a couple years now. Ill be spending the winter in the Yucatan and my plan is to be getting around by motorized bike. Im planning on getting a lockable trailer made when i get there to keep my gear and instruments in. Ill be doing research myself but thought id ask if anyone could recommend a reliable kit that could haul a 75-100 lb load. Im trying to keep the price to 200 or a bit more if necessary. If keeping within this budget means more work and tweaking on my part, than i can try to make that work. Thanks Alot, Lapo
  2. SubieGuy
    SubieGuy New Member
    Sep 3, 2012
    39
    More than a few people here are in favor of the "flying horse" engine kits. I personally have one and so far its been great!
    As for your towing needs; I can't see any kit being reliable enough on its own to tow that much weight. I'd personally look into a shift kit to go with the engine.
  3. lapo
    lapo New Member
    Oct 12, 2009
    Interesting. I talked with a well known kit seller and he said his 4 stroke kit would do the job. It was a super titan xc50s and rear mount chain drive. It was a bit out of my budget, though. So maybe the cheaper flying horse woulding really be up for it? It sure looks like an attractive kit. Can you recommend a quality, affordable shift kit? Thanks alot
  4. biknut
    biknut Active Member
    Sep 28, 2010
    6,378
    Welcome to the forum.
    I perfer Flying Horse also. I think an 80 would get the job done, but you might need to drop the gearing a little. I think you'd do alright with a 46 or 48 tooth rear sprocket. Stock is 44.
  5. SubieGuy
    SubieGuy New Member
    Sep 3, 2012
    39
    You'll find that shift kits will cost about the same as an engine. As far as I know, Sickbikeparts has the best shift kit out there for the money.
  6. OblivionsKey
    OblivionsKey New Member
    Oct 21, 2012
    36
    Honestly I would recommend a 4 stroke with enough torque. Because personally I wouldnt wanna have to find a runway for the 2 stroke and then get going fast enough with a 100 lb trailer to start the 2 stroke. Hopefully with the 4 stroke you could just pullstart it, let it warm up a bit and then pull away ( and you could easily help it by pedaling but atleast your engine would be already cranked ). But anywho that's just my 0.02$
