Rear wheel spinning w/o clutch
Discussion in 'Motorized Bicycle General Discussion' started by fischer550, May 1, 2014.
  1. fischer550
    fischer550 Member
    Mar 24, 2014
    234
    When I disengage the clutch (idle) my back wheel still spins. I have the cable as loose as it wants to go, and I took my air filter off and there was a bit of a gap between the bottom of the barrel and the carb, letting air get through, about 1/4 an inch. thoughts?
  2. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,714
    80
    your clutch & cable are not adjusted properly
    search this board for about 200 posts on proper adjustment
  3. fischer550
    fischer550 Member
    Mar 24, 2014
    234
    But I can pedal normally and it doesn't turn the motor over...
  4. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,927
    89
  5. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Here's another tutorial if Greg's didn't answer your question > http://motorbicycling.com/showthread.php?t=22726
    You said, "I have the cable as loose as it wants to go". That sounds like your problem. The clutch cable should never really be 'loose'.
    As long as the engine idles well don't worry about the throttle slide position. 1/4" sounds like a lot but as long as the idle speed isn't too hight, don't worry.
  6. fischer550
    fischer550 Member
    Mar 24, 2014
    234
    I meant the carburetor cable, my point was that I thought air was going into carb when it wasn't supposed to be. never thought about clutch
