rear sprocket and fat tires
Discussion in 'Motorized Bicycle General Discussion' started by dule, Jan 7, 2010.
  1. dule
    dule New Member
    Dec 23, 2009
    99
    hi does anybody know does the fat rear tire (in my case 24x3 with standard - narrow rim) gets in the way of a chain?!? just yesterday i've helped my friend to install a kit on his bika, and his 26x2.125 tires looks pretty close to the chain...
    and other one for you, would it be possible to mount a rear sprocket on a rear disc mount, and than run a rear disc brake caliper on the sprocket itself?!?
    (I know that i've seen sth about that but can't find it now...)
    tnx
  2. the paper boy
    the paper boy New Member
    Jan 8, 2010
    79
    I also had that very same problem with my rear tire. what i did to fix it was in sted of mounting the rear sprocket the way it tells you to. all I did was flip it around having the teeth facing out so that the chain is farther away from the tire. go on and try that out because it worked for me and i hope it will works for you too good luckusflg
  3. dule
    dule New Member
    Dec 23, 2009
    99
    tnx will have that in mind
    dance1
  4. the paper boy
    Jan 8, 2010
    79
    no problem hope it works for you if it does tell me please that would be nice thx.wee.
  5. dule
    dule New Member
    Dec 23, 2009
    99
  6. the paper boy
    Jan 8, 2010
    79
    Wow nice bike from what i can see the tire is about the same size that my bike tire is so i think the info that i gave you might work on it so why dont you try itdance1
  7. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    For fat tire Felt bikes, I usually add a extra rubber spacer between the sproket & spokes to give it extra chain/ tire clearance! ;)
