Really? Gear remover tool wont fit
Discussion in 'Motorized Bicycle General Discussion' started by geoldr, Oct 14, 2011.
  1. geoldr
    geoldr New Member
    Jun 19, 2011
    260
    Hey guys, so I am trying to prep for my centrifugal clutch install tomorrow. I found my gear puller tool, but as luck would have it, it doesnt actually fit onto the small gear. Its a little bit too small. Ill post a picture in an hour or so. But, theres no way I am doing it wrong right? It just screws right on?
  2. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
  3. MotorBicycleRacing
    Jul 28, 2010
    5,715
    35
    Yep, it screws right in.....
    I got a box of those pullers. Some of them have messed up threads
    but never seen one that was too small.
    Where are you in CA?
  4. geoldr
    geoldr New Member
    Jun 19, 2011
    260
    Yup, that's how I am trying to do it...
    Here is an image. Not sure if you can tell much. But i figure the side on the left screws into the space in the small gear. But its too small! Ill try again tomorrow after work. Maybe my angle was off, but I swear it didn't fit.
    Im in the Bay Area in Pleasanton in CA
  5. MotorBicycleRacing
    Jul 28, 2010
    5,715
    35
    You are using the wrong end and you have to
    remove the screw before you can thread the puller into the gear.
    The small end of the puller goes into the gear.
    #5 MotorBicycleRacing, Oct 14, 2011
  6. Goat Herder
    Apr 28, 2008
    6,251
    Just like in the peddle crank removal video he removes the bolt from the peddle crank arm and uses the puller.
  7. geoldr
    geoldr New Member
    Jun 19, 2011
    260
    Yeah, the gear puller has two parts to it. I took out the smaller part, and the bigger one that was left I was trying to put it onto the gear. It wasn't fitting though.
    Like this video
    Bicycle engine kit gear removal - YouTube
    EDIT: I am supposed to remove the screw first? Wasn't aware of that. will try that tomorrow.
