RAW engine, having issues starting. Carb replaced. No spark? Please help!
Discussion in 'Motorized Bicycle Trouble Shooting' started by RawRawRaw, Mar 9, 2013.
  1. RawRawRaw
    RawRawRaw New Member
    Mar 9, 2013
    16
    Hello!
    I got a project bike with a raw engine on it (I did not install the kit myself, just learning about it through an old used one that was sitting outside for a year)
    Previous owned said he replaced the CDI and spark plug, but did not know much about engines.
    Well, neither do I. But I got it to start a few times. cvlt1
    I took the carb apart, and the float has a bit of gas in it, and the bowl seal was cracked. So I bought a new carb, nearly identical, and put it on. Same issue.
    It turns as I pedal, but won't kick in.
    The spark plug looks okay, I think:
    https://www.dropbox.com/s/1t8k184g7456zwi/2013-03-09 17.45.39.jpg
    but the part of the (ignition coil?) that connects to the spark plug fell out:
    https://www.dropbox.com/s/27asqoadk5c7zbi/2013-03-09 17.44.55.jpg
    I put it back in, but not sure if the orientation of the copper cylinder piece to the clip looking piece matters, does it?
    I tried taking out the spark plug, connecting it, and pedaling, am I supposed to see a spark?
    zpt
    I have access to a dmm and such, not sure what to test for, if it is the spark, at this point I have no idea
    Any help is greatly appreciated!
  2. RawRawRaw
    Mar 9, 2013
    16
    I took some pictures of the wiring:
    Killswitch:
    https://www.dropbox.com/s/9pkzbxfiotkmppr/2013-03-09 19.01.31.jpg
    Two Y-splits:
    https://www.dropbox.com/s/p2okmmia5lg7a1i/2013-03-09 19.01.21.jpg
    Wires from engine:
    https://www.dropbox.com/s/o6o5uffoja0zsr2/2013-03-09 19.13.24.jpg
    White goes to nothing?
    https://www.dropbox.com/s/smuzqbd3n3ygok5/2013-03-09 19.01.14.jpg
    https://www.dropbox.com/s/5nyp2ow7s2u8axc/2013-03-09 19.01.06.jpg
    Green and Yellowred go to kill switch.
    Black from engine goes to yellowred to killswitch, and black to CDI
    blue from engine goes to CDI green and killswitch green
    CDI has black to engine and to killswitchs yellowred and blue to killswitch's green and to engine blue
    white from engine doesn't connect to anything.
    scratg
    is this wired correctly?
    #2 RawRawRaw, Mar 9, 2013
  3. maniac57
    Oct 8, 2011
    4,486
    Be sure that white wire does not touch. It will kill the engine. Take the plug out and hold it against the head while turning the engine over to check for spark. If no spark, check the mag coil under the sidecover.
    But first replace the junk stock plug wire. It unscrews from the coil. Search the forum for thureads on this.
  4. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,439
    39
    all looks good, but it wouldn't hurt to pick up a spare plug (NGK B6HS works in these) - when you put the plug cap back together, did you put in the small spring that goes under that brass plug? won't work without that
    if that's the problem & you can't find a new cap, you can strip the rubber back a bit on the wire & just wrap the wire onto the top of the plug (a small nut can hold it nicely)
  5. RawRawRaw
    Mar 9, 2013
    16
    Thanks for the replies!
    I insulated the white wire, but before I might've been grounded. Could that of done any damage to the coil/cdi/etc?
    Where does the spring go? What does it look like?
    My connect just like this:
    http://i.imgur.com/BWi6Bnv.jpg
    The part circled is what fell out and I put back in.
    Sorry, I don't follow.
    http://i.imgur.com/er2JMMv.jpg
    When I ride it like this there is a spark, but it's between the engine and the wire, not from the spark plug itself. (circled)
    #5 RawRawRaw, Mar 10, 2013
  6. RawRawRaw
    Mar 9, 2013
    16
  7. Toadmund
    Toadmund New Member
    Jan 19, 2012
    792
    Does it work?
    Looking at your head, don't know if it's blow-by but check your head gasket and then properly torque your head. It could cause loss of compression and a lean condition.
  8. crassius
    Sep 30, 2012
    3,439
    39
    where the brass piece screws into the black plastic there is a spring that goes under the brass - usually when the brass part pops out, the spring goes flying off somewhere
  9. RawRawRaw
    Mar 9, 2013
    16
    Got it. Well, I'm gonna get a new boot for spark plug and solder it into the old wire.
    Temp fix is just sticking the wire directly into the spark plug, lol.
    Not sure how the cable is glued into the CDI or what not, I was thinking just cutting it and splicing a new boot on - objections?
  10. crassius
    Sep 30, 2012
    3,439
    39
    no soldering needed - cap just screws onto wire - same with wire screwing into CDI, except that some new ones are glued so you have to dig out the glued part first
  11. RawRawRaw
    Mar 9, 2013
    16
    Ah, so I can get a new boot and just screw it in?
  12. 2door
    2door Moderator
    Staff Member
    16,301
    24
    No, you can't splice a spark plug wire. If you're going to replace it you'll have to get the old one out of the CDI. Most new ones are super glued in and it takes some work to get them out. Be careful and don't damage the threaded contact in the CDI that screws into the core (conductor) of the new wire.
  13. biknut
    biknut Active Member
    Sep 28, 2010
    6,365
    Here's a wiring diagram
    [​IMG]
  14. crassius
    Sep 30, 2012
    3,439
    39
    yep, the new cap will just screw onto the old wire - I note your wire may be messed up from being stuck on the plug, so be sure you can see the copper wire inside & hit it with the screw in the new cap (trim the rubber back a 1/4 inch or so to be sure you see the copper)
  15. RawRawRaw
    Mar 9, 2013
    16
    Thanks biknit, that's helpful, you should add the engine to it too!
    Got it. Sounds like it's easier to screw a good boot into the wire than trying to get the wire out of the CDI, right?
    The bike was running fine for 2 days (~6 miles?) and today it just died. Get's spark when I take the plug out so my ghetto fix is working. I had the petcock open all the way from the fuel line, and the previous owner warned me against that claiming 'this engine floods a lot'
    i took off the carb, opened the bowl, a little fuel leaked out, took out the spark plug, hopefully it will evaporate overnight, if it's flooded.
    any advice regarding this issue?
  16. biknut
    Sep 28, 2010
    6,365
    It's pretty easy to dig out the glue around the spark plug wire so you can unscrew it out of the CDI box. You just need a very small screwdriver. Not only is the stock plug cap a pos, but the spark plug wire itself is crap also.
    I buy copper core wire by the foot, and an NGK cap at my local motorcycle shop.
    If you carb leaks, it may be at an angle on the manifold. Try lowering the fuel level in the float bowl slightly, by bending the brass float arms.
    Always turn the pstcock off when the motor is not running.
