Questions about suspension forks for 700c
Discussion in 'Motorized Bicycle General Discussion' started by vincent713, Nov 20, 2011.
  1. vincent713
    vincent713 New Member
    Jun 2, 2010
    287
    I'm looking to put a suspension forks on my old Raleigh C30 bike with 700c tires. I found one on ebay but the forks are non threaded, I currently have a threaded setup on my stock forks. The question is can I use a non threaded forks on my bike? If yes, how can I make this work? I've never encounter a non threaded forks before.
  2. kevyleven007
    kevyleven007 Active Member
    Sep 25, 2008
    1,202
    ok.your gonna need a threadless headset and stem.or a pipe threader.
  3. happyvalley
    happyvalley New Member
    Jul 24, 2008
    786
    The conversion can be done and as 007 mentions you'll need a headset, stem and spacers. The old headset is removed and the new pressed in place, something many would probably feel most comfortable having done at a LBS. It's might also be necessary to cut the steerer to length.
    On another note, I know Suntour still makes an entry level threaded, 1" 700c suspension fork for around $100.
    #3 happyvalley, Nov 24, 2011
  4. vincent713
    Jun 2, 2010
    287
    Thanks for the reply, it seems a pipe threader would be a better idea for me. As long as it will fit my bike then I can go buy one. Thanks again for your input.
  5. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,825
    12
    I would avoid cutting my own threads. It is a very fine thread and the cutting die is hard to find. Get a 1" threadless headset and 1" threadless fork for easy installation.
    If you use a threaded fork, they come in a variety of lengths. The threaded fork steerer must match length of your steering tube or it cannot be used.
    If you can find an older threaded Marzocchi, the steering tube is replaceable and you can order different length steerer tubes on EBay. Avoid the old air forks unless you plan to rebuild them with spring or elastomer internals.
    I bought a lot of stuff that didn't fit before learning this.
  6. vincent713
    Jun 2, 2010
    287
    Would I need a threadless stem as well?
  7. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,438
    Suspension forks are MUCH easier to find for 1 1/8 steerer frame tubes than for 1 inch-
    so is it a mountain bike? I'm assuming threadless is usually 1 1/8" ? - Don't know- after my time I don't like threadless- no adjustment
    But if the frame tube is 1 1/8
    heres a cheap headset on ebay- and there are others
    1 1/8" Threaded Headset - Black - Steel | eBay
    in fact I think the threaded replacement suspension forks they sell threaded are more intended for mass marketed bikes like at Wal-Mart
    Here's a cheapie on ebay seaching "buy it now' there's others under bidding too.
    Ground Assault Suspension Fork Suspension fork | eBay
    OOOPS- that's 26" I guess- sorry!,
    Actually a 700C wheel will fit in it generally but you cant usethe cantilever braze-ons
    andhave to use a very short reach brake in the center hole of the arch-
    I have one with a 700 wheel and Campy brake
    You have to measure the head tube and have another 1 1/2 inches for the headset- You can cut a longer one down if the threads are long enough-
    that's if you wanted a threaded set-up at least
    and this is for a mountain bike with a 1 1/8 front tube and NOT a cruiser witha one inch head tube.
    and are less money than competition equipment
    Actually here it is- it really is a 27" wheel here- I have a 700 on a regular cruiser fork on the other build with the same kind of brake. And this one is a 1 inch fork to fit a cruiser.
    Colt droppers xct2
    #7 Nashville Kat, Nov 25, 2011
  8. happyvalley
    Jul 24, 2008
    786
    Yes you will if you convert to a threadless headset but if you do decide to go that route, it's really a superior design over threaded with more options available over a quill stem, especially for a comfort bike.
    #8 happyvalley, Nov 25, 2011
