Pre lubing a clutch cable
Discussion in 'Motorized Bicycle General Discussion' started by Greg58, Jan 29, 2013.
  1. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,937
    90
    I like a lot of members have broken a clutch cable, I installed the cable that came with my first kit as I found it and it lasted about two weeks. From that day forward I take the braided cable out of the housing and coat the cable with lithium grease leaving the last two to three inches of cable ungreased so the cable clamp will hold. The results were amazing, the clutch pull required was far less and the cable has been on the bike for a couple of years.
  2. 2door
    2door Moderator
    Staff Member
    16,310
    All of your cables, clutch, brake and throttle will benefit from lubrication. I found that a heavy oil is easier to apply than grease and coats the entire inner surface of the housing as well as the cable itself. In fact I use chainsaw bar & chain lube, the same as I use on my chains. Once a year seems to be sufficient.
  3. Greg58
    May 1, 2011
    2,937
    90
    Tom I do that now I just wanted to let those that are new to Mb installing to know this trick.
  4. bairdco
    Aug 18, 2009
    6,401
    49
    i've done that on every bike i've owned since i was 11 or so.
    an easy way to grease them (instead of oil) is to take a blob of grease between your finger and thumb, then run the cable thru them as you push it into the housing.
  5. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    I'm seriously considering using liquid wrench on my brake and throttle cables for my 4 stroke build.
  6. WightBoy
    WightBoy New Member
    Aug 30, 2012
    271
    I have used pb blaster on my cables with good results
  7. Greg58
    May 1, 2011
    2,937
    90
    Looks like we all have used different lubes, the one common thing is we all lube our cables.
  8. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,442
    6
  9. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    This may not be terribly relevant for many, but I thought I'd mention if you tend to ride in colder climates (significantly below freezing) the heavier oil & grease types tend to thicken up and increase cable drag, even preventing a full return. The lighter spray lubes like PB & Wrench don't suffer this, but haven't much longevity & require frequent reapplication.
    I'm not particularly recommending this stuff, but it's what I use due to the above as molybdenum is a "dry" lube, it does work quite well if a touch spendy: http://www.amazon.com/Bike-Dri-Slide-4oz-Needle-Nozzle/dp/B001F2Y25G
    #9 BarelyAWake, Jan 29, 2013
