Poo Poo Pipe??
Discussion in 'Motorized Bicycle General Discussion' started by zachattack, Jan 16, 2011.
  1. zachattack
    zachattack New Member
    Dec 2, 2010
    54
    ok i been wondering what is the poo poo pipe does it add performance and is it better then the expansion chamber just wondering thanks
  2. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    No - if anything their would be a slight reduction in performance over stock due to increased & untuned back pressure - it is however one of the quietest commercially available exhaust systems.
    A proper expansion chamber is the only exhaust choice that provides a performance gain on a two stroke :)
    #2 BarelyAWake, Jan 16, 2011
  3. zachattack
    Dec 2, 2010
    54
    thanks for the info i was wondering cuz the site dosnt say a single thing about it
  4. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,442
    6
    I use one and don't think there's any loss of power- and they are considerably quieter- the muffler section on mine is half again the length of the standard kit pipe,
    It's sorta really an expansion pipe in that sense.
    it does add a little bit of weight, which is not good in a second floor apartment.
    I had to cut and extend mine- the ones that are supposed to go on top of the bottom bracket are difficult to fit.
  5. Schwinn the Fox
    Schwinn the Fox New Member
    Aug 13, 2010
    187
  6. Nashville Kat
    Apr 20, 2009
    1,442
    6
    Not sure there's enough of the top pipe for this now- I used the old pipe I think-
    but you can extend the pipe with cut up aluminum can material- cut up, a big can wraps a couple of widths this size-
    clamp the extension top and bottom with worm hose clamps- I use two at each end and I covered the can aluminum with Chrome tape from the auto store-
    doesn't look too bad, but doesn't come apart-
    Yes- the pipe would fit very very very few bikes running over the bottom bracket and between the cranks- have to cut and run under-
    flexible electrical conduit may make a good extension too.
    my back muffler part was not as long and the welding really wasn't as bad
