1. motorized kodiak
    motorized kodiak New Member
    Aug 3, 2013
    105
    the place where the pedal screws on to the crank, the crank threads are striped about a quarter way through screwing in the pedal,what can i do to hold my pedal in place? , epoxy, wood glue silicon? im not sure, help would be much apprecitaed :)
  2. curtisfox
    curtisfox Well-Known Member
    Dec 29, 2008
    4,079
    44
    Make sure you have the right pedal there is a right and left hand threads on them Then try to put it in form back side might clean up the threads that way some.
    If it only a quarter of the way it still should hold just don't over tighten it JB weld would be about the only thing that might held it, other wise might have to change the crank..................Curt
  3. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    if there are 3/4 of the threads that are still good, do as curtisfox mentioned and then if you get the pedal to where it will screw into the crank all the way, then back it out until it is about half way out and then I would put a healthy amount of RED Loctite on the threads and screw it back in, let it sit for a few hours and then it should be solid from here on out, RED loctite is some very strong stuff once it is set in threads and would be my fix for that problem if there are enough good threads left to keep the pedal from wobbling around once it is screwed in tight.
    Map
    reddd
  4. 2door
    2door Moderator
    Staff Member
    16,301
    26
    One piece crank or three. Steel or aluminum? And JB Weld, glue, won't hold it no matter what you have. There's a lot of force applied to a bicycle's pedals. You do not want one to come off while you're pedaling hard. Especially if you have a men's frame. :(
    Try the suggestions from mapbike but to be safe I'd start looking for new parts.
  5. mapbike
    Mar 14, 2010
    5,380
    Ditto.....................!
    No kind of fix will be as good as new cranks unless you have a welder and then you have a bullet proof fix.
    Map
  6. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,428
    most bike shops will have a pedal tap- you can get that run through to clear any obstructions- 3/4 the thread left should still give you a pretty good grip I'd think, unless the part that's gone is REALLY REALLY opened up.
    the threading from the other way is a good suggestion too, and may be enough
  7. bluegoatwoods
    bluegoatwoods New Member
    Jul 29, 2012
    1,577
    All good suggestions......
    But I'd replace that crank.
    It's just plain easy with a one-piece. Three-piece is a bit more difficult. But a bike shop will do it if you don't want to.
  8. fatdaddy
    fatdaddy New Member
    May 4, 2011
    1,516
    Time to replace the crank, just drop by my place and pull a crank out of one of my old frames, Just kidding bro, thats a long way to swim for a crank. I say find a junker bike and steal the crank out of it.
    fatdaddy.
  9. motorized kodiak
    Aug 3, 2013
    105
    thanks for all the replys!
  10. Jim C
    Jim C Member
    Jul 11, 2010
    191
    Replace the crank is the best way. you can try to drill and tap the pedal end, screw it in as best you can then use a good grade Allen cap screw with a lock washer and a flat washer that might hold the pedal tight to the arm then again it might not
  11. motorized kodiak
    Aug 3, 2013
    105
    Hey everyone, i ended up changing the crank on my bike now it works perfectly!
  12. mapbike
    Mar 14, 2010
    5,380
    Thats great.... glad to hear you got it fixed up... ride safe.
    Map
    .wee.
  13. motorized kodiak
    Aug 3, 2013
    105
    thanks everyone for the help!
  14. 2door
    2door Moderator
    Staff Member
    16,301
    26
    And thank you, Kodiak, for getting back with your resolve. It's always good to hear that things worked out and how the fix was done.
    Have fun, ride safe.
