Pac Man Clip?
Discussion in 'Motorized Bicycle General Discussion' started by Avowed, Jun 5, 2011.
  1. Avowed
    Avowed New Member
    May 4, 2011
    25
    I got a bunch of Grubee Skyhawks, in the manual it says: ".. the idle and air fuel mixture screws have been epoxy sealed at the factory to avoid end user tampering.... if engine needs more fuel to run more powerful move the pac man clip on the needle down to the next notch position."
    Anyone have a diagram? I am wanting to know what I am looking for before i start in with these tiny parts. The bike is alot less powerful than my stinger kit.
  2. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,927
    89
    Go to the classic threads on the main page, here you will find all you need.
  3. Allen_Wrench
    Feb 6, 2010
    2,787
    They actually CALL it a "pac man" clip? Man, I haven't played Pac Man since I was in junior high. There, I dated myself. When I call 'em C-clips, people at least know what I'm talking about. (Pac-Man clips. - sheesh!)
  4. Greg58
    May 1, 2011
    2,927
    89
    I have heard the clip called a-lot of things, I call it e-clip.
  5. DuctTapedGoat
    DuctTapedGoat Active Member
    Dec 20, 2010
    1,179
    8
    I just call it the needle clip.
    Either way, you can get that screw working, just takes some heat to remove epoxy.
  6. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
    Looks like Grubee (feh) is getting real technical with the terminology.
    Next thing you know, he'll be calling Philips-head screws plus (+) screws.
  7. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    LOL............!
    Or if they are turned just a bit then they would be ( X ) screws.......!
    This is funny, that "pac-man clip" title really got my attention, I knew what it was refering too but I have also never heard it called that before, but hey it does look like Pac-Man sorta so no harm no fowl in my book.....
    first pic is an E-Clip - Second pic is a common type C-Clip
    But as Allen Wrench said we call them needle clips on these engines, that keeps it real simple and to the point.......
    Pac Man Clip......may be the next term used to describe them after this post, heck I might just pick that up myself.......
  8. Allen_Wrench
    Feb 6, 2010
    2,787
    Hmmm. Now I'm confused. I've been calling the first type a "C-clip", and that second one a "Snap-ring". So if I gotta buy one, what do I ask for? Anybody here work at a hardware store?
  9. rohmell
    Jun 2, 2010
    1,533
    To me, it would be more appropriate to call the little washer in the NT carburetor a 'Pac Man clip'.
  10. rohmell
    Jun 2, 2010
    1,533
    C Clip: (because it looks like a C)
    E Clip: (because it looks like an E)
    External Retaining Ring:
    Internal Retaining Ring:
  11. Avowed
    Avowed New Member
    May 4, 2011
    25
    thanks for all the replies! I apologize for any confusion the term may have caused; the instructions actually call it that...
  12. rohmell
    Jun 2, 2010
    1,533
    No need to apologize, the only one confused here is Grubby Grubee (feh) who seems to be making up names for parts instead of using established nomenclature for standardized parts...
  13. sketchman
    sketchman New Member
    Mar 23, 2011
    168
    I want to write the next Grubee manual.
    The Pac Man clip goes on the Dope Wars needle, which regulates the A/F ratio by sliding in and out of Mario's gas pipe. Have fun and be sure to dodge the bananas. They are a slippery.
  14. Allen_Wrench
    Feb 6, 2010
    2,787
    ROFLMAO!!! Yeah, you could call it "The Idiot's Guide to Building Motorbikes for Dummies" lafflafflaff
  15. Avowed
    Avowed New Member
    May 4, 2011
    25
    So to increase the power I am to move said pac man clip... But which way? Towards the cylinder or away?
  16. Greg58
    May 1, 2011
    2,927
    89
    Where you run the e-clip depends on what your spark plug looks like, go to the classic threads and look at the how to instructions on spark plugs.
  17. DuctTapedGoat
    Dec 20, 2010
    1,179
    8
    Richer is "down" on the needle, leaner is "up" on the needle.
  18. merchant810
    merchant810 New Member
    Jun 13, 2011
    17
    I am a newcomer and have ordered the grubee skyhawk as well. Its still new but after half acceleration it loses pulling power and gets to a point to where it is revved so high it just vibrates and seems like its freespinning. my friends cheaper motors respond instantly and take off fast why is this one acting so poopy
  19. DuctTapedGoat
    Dec 20, 2010
    1,179
    8
    First, you should really make a new topic when asking stuff like that, it's not really related to this thread.
    But either way - you need to tighten your clutch.
    1. Adjust the clutch lever's camshaft to be tight against the bucking bar (pin/rod at center of motor's drive sprocket).
    2. Lock your clutch.
    3. Open the largest cover on the motor (right side) and look at the left gear. There's a flower nut and a locking screw. Pull out the locking screw and turn the flower nut CW to tighten it, and CCW to loosen it. You want it tight enough to where it won't slip when you accelerate, but loose enough to where the clutch will disengage so you can idle.
    4. To test it, find a hill and accelerate up it. If your clutch keep slipping, tighten it (CW) one notch and try again. Lather rinse and repeat. Next test is to lock the clutch and lift the back wheel off the ground. If the wheel turns at all, you need to loosen it (CCW) one notch and try again. Lather rinse and repeat.
