One more break in question
Discussion in 'Motorized Bicycle General Discussion' started by MonkeySeller808, Oct 24, 2011.
  1. MonkeySeller808
    MonkeySeller808 New Member
    Sep 17, 2011
    29
    Hi everyone,
    I read around the forums about the break in period and I have questions. People been saying you will have a power increase after you engine have been broken in. My question is how much of a power increase? Will I know the difference? I am currently using a 32T sprocket and I can reach 25mph on a straight away and 30mph on a slight downhill. I have a 2 stroke engine.
    Thanks everyone I will post some pictures of my first build soon, when it stops raining!
    dance1
  2. Mozenrath
    Mozenrath New Member
    Jan 13, 2011
    340
    Honestly, I never noticed much of a difference in performance after break-in. But then again, I have never really used an odometer or a speedo.
    That's strange because with a 32T sprocket, you should get at least 30mph on a flat grade. Last I calculated, I got a max of 32 mph on a flat road with my 66cc engine with the 44T sprocket. I've never used a smaller sprocket, but supposedly the smaller you go the more speed you'll get but less uphill power.
    What mixture are you using for your break-in period? If you're using a 16:1 mix like the chinese instructions say, try instead using a 24:1 mix. Oil in the western world is of better quality so 16:1 is a lot of oil to use. Won't hurt to use 16:1, but you'll get both an greasy engine and a slight decrease in power.
  3. MonkeySeller808
    Sep 17, 2011
    29
    Thanks for your answer. I am using a 16:1 mixture like the instructions said to. I will switch to 24:1 when I fill up my gas container again. Thanks again.
  4. alienboy366
    alienboy366 New Member
    Jun 23, 2011
    114
    whoa that too rich. you should break in with 24:1 and later run 32:1 which is way sufficient. You have too much oil.
  5. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    I feel that 16:1 is also too much oil. What does your plug look like. Before I found forums I too did the same on my first build. With each additional, build I started with 24:1 and on to 50:1. Using Amsoil.
  6. MonkeySeller808
    Sep 17, 2011
    29
    I checked my plugs the other day and it was clean, little grey( from lead lol). But other then that it's all good.
  7. Al.Fisherman
    Sep 9, 2009
    1,966
    You want it tan, so a little less oil might do the trick.
  8. MonkeySeller808
    Sep 17, 2011
    29
    Thanks for the tip.
    usflg
