Occasional carby leak
Discussion in 'Motorized Bicycle General Discussion' started by Henshooter, Apr 16, 2014.
  1. Henshooter
    Henshooter New Member
    Feb 10, 2014
    275
    Hey guys ,I seem to have an unusual problem with my carby , I'll star by saying pin and jet clean as a whistle , carby float in great condition , brass tang is in great condition and pin on it is fitted correctly but despite this.......
    I keep on occasionally getting major leaks from the carby , for example I took my build to the shops ,no leaks prior to trip , pull up at the shop ,lock her up and get the shopping , come out to the smell of 2stroke :( , look at belle and she has a pool of fuel underneath her , I tap the carby and she is dripping very badly , she starts and runs well with slight 4stroking when taking off ( I believe from an excess of fuel in the system) ,after this burns off she runs beautiful ,I get home check for the leak and it's gone , which sux coz I can't diagnose the problem when she isn't leaking , it's happened 4or 5 times now and it's driving me nuts
    Any ideas as to what the problem is and how I can stop it ,oh I have already bent the tang arms down to slightly lower the fuel level in the carby
    Regards Henshooter
  2. Kioshk
    Kioshk Active Member
    Oct 21, 2012
    1,153
  3. Kioshk
    Oct 21, 2012
    1,153
    Which carb hast thou? On the NT, this can occur if the plunger gets stuck. If you have the NT, check the plunger's action for hang-up, and observe its interaction with the tang.
  4. 2door
    2door Moderator
    Staff Member
    16,310
    Hen,
    Are you using an in-line fuel filter? This sounds like crud getting caught in the float valve. The kit tanks are notorious for having rust, dirt and scale in them. They need to be cleaned and flushed before installation and then a good in-line filter installed between the tank and carburetor.
    Also it is always a good idea to shut off the fuel petcock when the bike is parked. Even with a properly working float valve fuel can seep, especially if the petcock doesn't shut off completely, and give you the condition you describe.
    Check the petcock to see if it completely closes in the off position.
  5. Henshooter
    Feb 10, 2014
    275
    Thanks Tom ,I've checked the tang and action it seems fine ,also I've always run a good inline filter , yes admittedly I've occasionally left the fuel valve in the on position ,lesson learned I guess ,it is one of those mulder and scully mysteries I guess
    It just baffles me as to why it only occasionally does it ,apart from this issue she runs sweet and doesn't miss a beat anymore
    Cheers for the advice Tom
  6. Henshooter
    Feb 10, 2014
    275
    HAHA !!! Your a funny bugger Kioshk :)
  7. Theon
    Theon New Member
    Jan 20, 2014
    1,440
    How level did you get the carb?
    Can you post a pick of the carb and inlet manifold please, I may be able to send a better manifold?
  8. Henshooter
    Feb 10, 2014
    275
    Carby is as level as I can get her Theon , I just can't put my thumb on this problem , I've checked the interaction between the tang and the valve arm and it all seems to be fine , but the main issue is I can't diagnose the problem because it only ever happens when I'm out and ripping the carby off in the middle of the street when the problem is happening is least from desirable in my neighbourhood .
    The inlet manifold I have on this kit is slightly larger than the regular one and uses Allen key bolts to secure to the head ,it's quite small being only about 1 inch or 3cm long ,the mouth of the inlet is also larger than the regular model and the bolts on it are roughly 4 mm further apart from a regular kit , I've got the manifold inlet you sent me but It won't line up at all , I would have to mill the anchor points at least 4 mm either side to allow it to fit and the same goes for the internal diameter of the inlet
    Christ my head is spinning
    Regards Henshooter
  9. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    You sure it wasn't made by Holly?
    :D
  10. Kioshk
    Oct 21, 2012
    1,153
  11. Theon
    Theon New Member
    Jan 20, 2014
    1,440
    Sean I will send you the manifold I made for my motor the same as yours, so it will match the inlet studs, which are 40mm apart, and M5 threads. I no longer have any use for it.
