Northwoods Ridgedale Cruiser Build
Discussion in 'Motorized Cruiser Bicycles' started by biknut, Sep 29, 2010.
  1. biknut
    biknut Active Member
    Sep 28, 2010
    6,365
    This is my first. I just bought this bicycle for the honors. It's all alloy, about 30 lb total. All I've done so far is remove the fenders. It's made by Kent. I've ordered a black slant motor kit from Zoombicycles, but it's not here yet.
    Lemme soo if I can figure out how to post a picture of my bike.
    [​IMG]
    #1 biknut, Sep 29, 2010
  2. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    Thats gonna be a sweet ride biknut (^)
  3. fishguts
    fishguts New Member
    Sep 7, 2010
    313
    I'm looking forward to seeing how this goes as I've been considering buying the same bike for my next project. Best of luck with it!
  4. darkhawk22
    darkhawk22 New Member
    Aug 17, 2010
    733
    Good luck! I'm curious to hear how the motor kit from zoombicycles works out.
  5. biknut
    Sep 28, 2010
    6,365
    My apologies ladies and gentlemen, this is my first a attempt at posting pictures on this forum and I'm having a little technical difficulty. Bear with me, I can do this.
    [​IMG]
    By biknut at 2010-09-29
  6. paul
    paul Active Member
    Dec 23, 2007
    5,536
    8
    no apologies nessesary. great looking ride! gonna make one heck fo a motorized bicycle. glad to have you with us biknut
  7. r00t4rd3d
    r00t4rd3d New Member
    Aug 2, 2010
    310
    Ive read more bad things about aluminum frames then good. Keep an eye out for cracks. BUT..... I wish my bike only weighed 30lbs ! More like 130lbs.
  8. scotto-
    Jun 3, 2010
    6,530
    6
    First let me say....welcome to the forum! And secondly, you could not have picked a better bike to motorize....PERIOD! And I don't only say that because I own one and have built several of them, it is just hard to beat this kind of bike for the money....seriously. The Northwoods is a pleasure to ride with or without an engine and furthermore I've got almost 4,000miles on mine with a 4-stroke engine and the frame is as worthy as any and more worthy than most, especially for the money.
    When people bad mouth aluminum frames and blah blah blah alloy frames crack.....guess what, all frames can crack, titanium, cro-moly, mild steel, aluminum, carbon fiber. Aluminum rocks and don't you forget it! Great bike you got there, can't wait to see it motorized.....cheers!
    Here's my No wood....Ridgedale.....
    [​IMG]
    [​IMG]
    Enjoy your build and don't hesitate to ask questions if you run into issues....this place has the answers!dnut
  9. biknut
    Sep 28, 2010
    6,365
    Thanks I feel the love guys. This is my new home. Even though I'm a novice with motor assisted bicycles I've done a lot of custom fabrication on my motorcycles.
    I never even heard
    of these bikes before 3 weeks ago, but I'm already hooked. If it has 2 wheels and burns gasoline I love it.
    I've learned from experience that forums like this are where all the knowledge is found, so I plan to ask a lot of questions. Someday I'll give back too.
    Right now I'm really looking forward to getting started. I have parts ordered from different suppliers, and I'm sure I'll need a lot more before I'm through. Knowing the way I work I'll probably have the first $1000 home built lol.
    There's 2 areas I find suspect. The stock motor mounts, and the rear sprocket attachment. I'm trying to get a sprocket adapter and sprocket from Pirate, but they're out of stock of sprockets so I wait. I also don't care for the stock motor mount hardware. I'll probably make something of my own but I need the kit in my hand first.
    I wonder whats better, rubber mount, or solid mount. I saw an ingenious mount made from hockey pucks that looked interesting. From what I've seen so far opinions are all over the map.
    Since I already have 3 motorcycles I want to try to not make my bicycle look like a little motorcycle as much as possible. Scotto's bike looks a lot like what I'll probably end up with.
    I'm planning to mount two 1 liter fuel bottles on a water bottle cage mounted to the seat post for a fuel tank. Also looking for a rear rack I like.
    All suggestions welcome.
    #9 biknut, Sep 30, 2010
  10. biknut
    Sep 28, 2010
    6,365
    Another part I question is the chain tensioner. Why aren't there any spring loaded ones? I don't like the way the stock one looks.
  11. fishguts
    fishguts New Member
    Sep 7, 2010
    313
    I'm wondering how difficult it would be to remove all the stickers? Can they be peeled off or are they under a layer of clear coat?
  12. scotto-
    Jun 3, 2010
    6,530
    6
    To answer your question, they don't peel off....unless left in the sun for 70yrs. or so. Simple fix, if you look real close at the pics of my bike (real close), you'll see that I use a Sharpie permanent marker on them....it works very well and easier and cheaper than new paint....I'm not kidding!
    #13 scotto-, Oct 1, 2010
  13. fishguts
    fishguts New Member
    Sep 7, 2010
    313
    Hmmmm ... looks like I'd have to scrape them off, sand out the bike and repaint. Durn. Was hoping that wasn't the case as that can make the difference in what bike I buy.
    But I do like these bikes and they look like a good base for a build.
  14. Creative Engineering
    Sep 20, 2008
    1,668
    You won't need the chain tensioner for this bike. Tension the engine drive chain at the drop-outs using the adjusters...just like a motorcycle...add a spring loaded or rigid idler on the pedal chain side.
    pics:
    MANIC Mechanic Parts.htm
    Jim
  15. biknut
    Sep 28, 2010
    6,365
    Thanks a ton. It helps a lot seeing the same motor already mounted in a bicycle just like mine.
    Using the tensioner on the peddle side??? I never thought about that, but that does solve the problem. I have seen spring loaded chain tensioners available for the peddle side. That solves that problem.
    I already have the sprocket adapter, and sprocket on order from Pirate. They don't have a motor mount like that on their webbsite. I'd sure like to get one. Do you offer one, or can it be special ordered through a distributor like Pirate?
  16. Creative Engineering
    Sep 20, 2008
    1,668
    The engine mount in the photos worked great! I assembled that bike a year and a half ago, and the customer rides it almost daily.
    Out of 20 or so of that design, I had several that cracked at the bends. They were all local builds that were fitted with one for testing. 3 customers had engines that vibrated a bit on the excessive side. It was on these bikes that the mount broke. One bike vibrated so badly that when sitting still and revved...the whole bike was a blur...
    I have since done a re-design that includes all machined parts.
    I'm working on a motor mount program for Pirate Cycles and Pistonbikes. I'm waiting to see if any of the 100+ that have been shipped fail before producing mass quatities.
    I never had a problem with the old, pan style, mount...but then again, I chuck engines that vibrate badly. They get a crank balancing, or are used for parts.
    Jim
  17. biknut
    Sep 28, 2010
    6,365
    Today I made a little progress. I bought 2, 30 oz aluminum fuel bottles from REI. My local Bates Discount Cycle supplied this 3/8 pipe thread petcock for $14, and Turner hardware, the best hardware store on the planet, had a tap and die plus a brass lock nut. This is what I ended up with. I'm going to use 2 of these bottles mounted to a bottle cage mounted to the seat post for fuel tanks.
    [​IMG]
    [​IMG]
    By biknut at 2010-10-01
    [​IMG]
    [​IMG]
    #18 biknut, Oct 1, 2010
  18. biknut
    Sep 28, 2010
    6,365
    If I use the horizontal drop outs to adjust my motor drive chain then I think these tensioners would do the trick for tensioning the peddle chain.
    This one should probably work.
    [​IMG]
    For some reason I'm leaning more toward this bracket which would allow me to use lots of different kinds of tensioners.
    [​IMG]
  19. biknut
    Sep 28, 2010
    6,365
    Here's my fuel tanks finished boys and girls. Not a great look, but not too bad either. Now if I just had motor.
    [​IMG]
    [​IMG]
    [​IMG]
