No more flats!... I hope
Discussion in 'Motorized Bicycle General Discussion' started by ocho ninja, Aug 4, 2012.
  1. ocho ninja
    ocho ninja New Member
    Jan 14, 2012
    564
    I'm way to work today I got a flat.
    Good tire, good tube, and tube liner.
    Either way a very small nail and a industrial staple took me down at the same time. Got someone to pick me up and get me to work.
    While on the clock, I took apart my rear wheel and patched my tube for two holes.
    I didn't wanna get a flat again so I began to think of stuff that will make a good tube liner.... I though layered duck tape sounded like a good idea but then a I saw an old tire strap from one of my jobs car trailers.
    Its about 2mm thick and very hard to stick a knife trough... Got a long enough piece, fit it in my tire, and aired it up.
    Hopefully no more flats, at least in the rear wheel.
  2. KCvale
    KCvale Well-Known Member
    Feb 28, 2010
    3,942
    29
    Clever ;-}
    I am curious about your 'good tube, tire and liner' however.
    I bullet-proof tires with just an HD tube, great liner and just stock tire.
  3. xenodius
    xenodius New Member
    May 23, 2012
    150
    I used to live in Idaho, and when I'd get back from mountain-biking my tires would be FULL of goatheads, some of them a couple inches long. I couldn't get through a ride without ruining a tube.
    I got a liner, and it didn't help.
    Then I went to a bike shop and was recommended a teflon-coated liner, and 6 years later I was still using the same tube. It's very, very hard... but most importantly, slick enough to deflect sidewall punctures to the front, and front punctures to the sidewall. This may cause damage to your tire, but your tube should be just fine =)
    And of course, don't forget excessive amounts of slime =)
  4. ocho ninja
    Jan 14, 2012
    564
    I have a serfas drifter tire, a thicker than average tube and a tube liner
    And I've already had two flats with that set up
    Hopefully this home-brewed liner prevents me from getting any more flats.
    When they start changing the straps on the trailers, I'll try and get a hold of a couple more for my other bikes
  5. Pilotgeek
    Pilotgeek New Member
    Apr 6, 2011
    403
    I have to second the teflon liner. The biggest benefit is that it doesn't just stop sharp objects, it deflects them away from the tube. I also use a really thick slime tube, and tires with a kevlar belt. Never had a flat once in near 2000 miles.
  6. Stoney
    Stoney Member
    Jan 23, 2009
    78
    Good to know
  7. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    16
    When I was younger I used to cut the sidewalls off old tires and use them as tire liners. It took some work to get the tube to not pinch. Usually just airing it up and letting the air out several times worked.
    Now a days i just use old inner tubes as liners.
  8. ocho ninja
    Jan 14, 2012
    564
    I jinxed my self.
    Got another flat and I just had replaced the tube with a $10 heavy duty one
    It was a 1" screw that went trough my new home brew tire liner.
    Idk if any type of tire liner, tube, or tire combination could stoped that sharp SOB of a screw:-||
  9. KCvale
    Feb 28, 2010
    3,942
    29
    Bummer Ocho, where are are riding to keep getting flats?
  10. Pilotgeek
    Apr 6, 2011
    403
  11. ocho ninja
    Jan 14, 2012
    564
    I ride to work and back, about a 28 mile round trip.
    All ride in is in the streets, but most of time on the side of road cause my little motors can't always cruise with traffic.
    And lol that a funny way to get a flat
