no idle
Discussion in 'Motorized Bicycle General Discussion' started by severedcorps, Aug 6, 2010.
  1. severedcorps
    severedcorps New Member
    Jul 13, 2010
    54
    my bike has beenworking completely fine, and now it won't idle.
    i have about 600 km on it.. it runs fine, no loss of power, it just won't idle.. I'm stumped.. ive tried turning the screw in all the way and unscrewing it 1/8 at a time.. sometimes it will idle for 1 - 3 seconds and then cut out.. it runs fine all else..
    anything I should look for?
  2. wezwheels
    wezwheels New Member
    Sep 9, 2008
    45
    check for air leaks. make sure you tighten all your bolts around the manifold and the carb. then you can spray a little carb cleaner or some starting fluid around the carb. see if the unit wants to stall or the rpms change any. if it does or the motor sounds different. you know you got an air leak. be careful with the hot motor. after all the fluids can ignite. if none of that works, get back with us and will try something else. no such thing as crazy here. wez
  3. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    Tighten the throttle cable a bit if need be.
  4. severedcorps
    Jul 13, 2010
    54
    throttle cable is as tight as can be. where would I be looking for air leaks? when i have the screw turned in all the way it will idle for 10 - 30 seconds before cutting out.. i dont have any carb cleaner or starting fluid, so if i dont need to buy this it would be better..
    I think it must be an air leak or something, but I can't find any leaks.. hmm
  5. severedcorps
    Jul 13, 2010
    54
    im going to get a friend to blow some smoke around the carb and see if it gets sucked in the engine, then ill know if i have an air leak... this should work, right?
  6. leftywoody
    leftywoody New Member
    Aug 23, 2008
    405
    You can spray just a touch of starting fluid from a can on the joint between the jug and the intake manifold and see if the engine revs higher . After much head scratching , I just went ahead and replaced that gasket and it helped me eliminate my idle woes . Sorry, I didn't see at first that you had a starting fluid, funding shortage . If you fix that gasket with a new one it will work .
    #6 leftywoody, Aug 7, 2010
  7. severedcorps
    Jul 13, 2010
    54
    i think i will replace the gasket on the intake and see if that helps.. how much would starting fluid cost?
  8. Nitrohorse
    Nitrohorse New Member
    Aug 1, 2008
    56
    Typical HT two cycle..leaking intake manifold. Take a Benz-O-Matic torch and turn the gas on without lighting it. Move the torch around the intake/case and listen to hear if the rpms increase. If they do, you found your leak.
    #8 Nitrohorse, Aug 8, 2010
  9. severedcorps
    Jul 13, 2010
    54
    and when do I do that if the bike won't idle?
    when im riding? and my torch is completely out, i have to wait til i get a new one or borrow from a friend
    #9 severedcorps, Aug 8, 2010
  10. leftywoody
    Aug 23, 2008
    405
    Save your mulah and buy a gasket and replace it .
  11. severedcorps
    Jul 13, 2010
    54
    yea im going to buy a gasket.. for the intake and exhaust.. i can seal with silicone right?
  12. Bikeguy Joe
    Jan 8, 2008
    11,529
    Or buy a dollars worth of gasket paper from the local mower shop, he will probably help you with cutting it if you take the manifold or old gasket in with you.
  13. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
    Don't forget to check the crankshaft seals for air leaks as well.
  14. leftywoody
    Aug 23, 2008
    405
    Use gasket sealer designed for intake manifold gaskets and follow the directions on the tube . Get it at an auto parts store and if you are using a gasket use the sealer sparingly ,not too much or it will obstruct your flow of gas . Just a paper thin layer on the surface of both sides of the gasket . Silicone sealer is made for many other differant applications but intake manifold sealer is what you need .
  15. Bikeguy Joe
    Jan 8, 2008
    11,529
    In a pinch, just about anything will work, especially for the financially challenged.
  16. Allen_Wrench
    Feb 6, 2010
    2,787
    Ya know, I'm sure this is something that would have stood out like a sore thumb, but did you check your choke to be certain it's staying wide open when you ride? I personally have a history with loose choke nuts. I'm also curious to know which notch your needle valve is set on. Second from the top seems to work well for most people. If you've already ruled these things out, feel free to ignore me.
