ngk spark plug for slant head
Discussion in 'Motorized Bicycle General Discussion' started by gra1972, Aug 21, 2011.
  1. gra1972
    gra1972 New Member
    Jun 21, 2011
    17
    hi guys just wondering if anyone can help, is there a ngk spark plug available for the slant head ?
  2. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,923
    88
    b6hs is a good plug for both 48 and 66cc engines.
  3. gra1972
    gra1972 New Member
    Jun 21, 2011
    17
    will it hit the piston as the plug that was taken out is short where it screws into the head ?
  4. Greg58
    May 1, 2011
    2,923
    88
    Not on mine, I run a grubee 48cc slant head and use the b6hs in it. If it is the same china girl engine kit you should not have any problems. Get the piston at top dead center and screw the plug in, then screw it out and see if the gap closed up if not it did not hit.
    #4 Greg58, Aug 22, 2011
  5. MarkSumpter
    MarkSumpter New Member
    Nov 27, 2010
    474
    I run the same plug in a 66 that works fine.
  6. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    All 5 of my HT builds use that same plug...no problems.
  7. wan37
    wan37 New Member
    May 29, 2011
    343
    I have a 48cc slat head too,but can't find a place with that nkg b6hs to buy from.Please tell me where to find it or a nother brand....Thanks
  8. MarkSumpter
    Nov 27, 2010
    474
    Pep Boys, Auto Zone, O'reilleys, NAPA Auto Parts etc. They can also cross reference it to AC Delco, Champion and other plug mfrs for you.
  9. Greg58
    May 1, 2011
    2,923
    88
    O'rielley's here stocks the b6hs.
  10. DaveC
    DaveC Member
    Jul 14, 2010
    970
    And if you really can't find the plug Sick Bike Parts lists them.
  11. Al.Fisherman
    Sep 9, 2009
    1,966
    #11 Al.Fisherman, Aug 22, 2011
  12. phinseth
    phinseth New Member
    Oct 18, 2011
    anyone know if a ngk bp5hs or a champion L90c plug will fit a boy go fast 66/80cc slant head motor. my stock plug crapped out on me so i need a new one. and my auto parts store only carries these 2. or should i go with the ngk b5hs plug off of sick bike parts?
  13. Greg58
    May 1, 2011
    2,923
    88
    The "p" is for the extended tip, it works in my slant head 48cc. With ngk the lower the number the higher the heat range, run it and do a plug check or chop as it is sometimes called and look for signs of heat related problems.
  14. wan37
    wan37 New Member
    May 29, 2011
    343
    Phinseth I running the ngk b6hs its great plug it's not as hot as the b5hs I would start with the 6 series first if not hot enough change there cheap enough to change.I can get them at most auto parts stores.
  15. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    I use the BP7HS and have no issues I also use 2 aluminum head gadgets though however it never hit the piston when I had just a one.
    I just put the second one on because, I read told me you can get more compression or some thing
  16. Greg58
    May 1, 2011
    2,923
    88
    I think you have the gasket idea backwards, adding a second gasket lowers the compression.
  17. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    Yes Greg your 100% correct in fact before i put in the second gasket I was getting blow by out of the single gasket when I swapped to angle head because of to much compression.
    However when I put in the second gasket "Even though one would think this will not fix your blowout issue " it did & the only reason it did was because " like you stated Greg "it lowered the compression" & stopped all that black oil from getting all over my bike and my legs
