Newbie from Montana
Discussion in 'Introduce Yourself' started by Scottyr50, May 26, 2010.
  1. Scottyr50
    Scottyr50 New Member
    May 25, 2010
    I recently installed my 80cc kit. It works fairly well except for the generator/light kit I installed. It burned out both bulbs after about a mile. Also the engine started to sputter after about 8 miles. I did make it home. The engine starts and idles well, but after going full throttle for a while it starts to sputter. any suggestions?.flg.
  2. CoastalCruiser
    CoastalCruiser New Member
    Apr 28, 2010
    338
    Full Throttle isn't recommended until after the egine is broken in - usually about 5 tanks of fuel. As for the burnt out bulbs, did you get a 12 volt charger and 6 volt lights?
  3. city of angels
    city of angels New Member
    May 24, 2009
    470
    if you have one of the generators lightsthat hook up to the tire dont hook it up to the rear hook it up to the front tire and like coastal cruiser says full throttle is not recomend it i did that once and i had to buy a new engine whats you oil to gas mixture usually to much oil could cause you bike to sputter causing the spark plug to get glog and not produce a spark
