New Motor Option to consider?
Discussion in 'Motorized Bicycle General Discussion' started by MikeN, Aug 20, 2011.
  1. MikeN
    MikeN New Member
    Aug 15, 2011
    10
    Has anyone considered something like the DLE111?
    11hp and only around 10lb!
    [​IMG]
    Specifications:
    Stock Number: DLEG0111
    Displacement: 111 cc (6.773 cu in)
    Bore: 1.77 in (45 mm)
    Stroke: 1.38 in (35 mm)
    Weight: 6.3 lb (2.86 kg)
    RPM Range: 1,300-8,500
    Output: 11.2 hp @ 7,500 rpm
    Requires: unleaded gasoline, oil, ignition battery & propeller
    Includes: electronic ignition, mufflers, spark plugs, gaskets, bolts, machined aluminum standoffs, throttle arm extension & mounting template
    Suggested Propellers: 26x12, 27x10 & 28x10
    Technical Data:
    Manifold: Double V-type, reed-valve, bottom induction
    Ignition Battery: 4.8-6.0V NiCd or NiMH, 6.6V LiFe or 7.4V LiPo pack (LiPo use requires voltage regulators.)
    Compression Ratio: 7.6:1
    Gas/Oil Mix: 30:1
    Replacement Spark Plug: NGK CM6 (DLEG5510) or equivalent
    Weights (individual): Engine: 88.2 oz (2,500 g); Exhaust (2): 7.1 oz (200 g); Ignition: 3.9 oz (110 g)
  2. rustycase
    rustycase Gutter Rider
    May 26, 2011
    2,746
    That's really nice, Mike.
    What's the cost and source?
    rc
  3. MikeN
    MikeN New Member
    Aug 15, 2011
    10
    They certainly aren't "cheap".... figure close to $700, and that includes muffler(s) and electronic ignition.
    [​IMG]
    They have a few options too. A 55cc which is 5.5hp and weighs ~5 lbs, and a 170cc that is 17hp and weighs 10lbs :)
    Next issue is figuring out how to adapt the drive, but I don't think it would be terribly difficult.
    #3 MikeN, Aug 20, 2011
  4. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,816
    10
    That mill may fit a stretch bike OK. Not much else.
  5. 2door
    2door Moderator
    Staff Member
    16,301
    25
    Model airplane engines have been discussed here in the past. The general consensus being that although they make the horsepower they don't produce enough torque to be a viable power plant for a motorized bicycle. They certainly are beautiful little engines however and I'd like to see some real world experimentation with one. But, alas, the price factor will keep most of us just wondering.
  6. rustycase
    May 26, 2011
    2,746
    LOL
    Tom, you are too nice !
    "Wondering" :)
    xcuse me while I add a bit more water to the soup.
    Best
    rc
  7. MikeN
    MikeN New Member
    Aug 15, 2011
    10
    hrmm... well a Grubee 66/80 is 8.5"h x 7"l x 5"w, and the DLE111 is 7"h x 10"l x 7.5"w. Not significantly larger really.
    And if you compare the DLE55 (55cc) it is only 3.5" x 6" x 7.5"
  8. Gary Harris
    Gary Harris New Member
    Jul 31, 2011
    86
    I build and fly RC planes and will agree with Tom. These engines are designed for a steady RPM and not for a variable torque load like MB's.
  9. decoherence
    decoherence New Member
    Aug 23, 2010
    476
    i like it's biggest brother.
    [​IMG]
    $ 1649.99 !!!
    i don't like it that much.
  10. Tohri
    Tohri New Member
    Aug 28, 2010
    159
    My immidiate reaction to that motor was 'Why not put a propeller on the thing in pusher config, and rack mount that sucker!'
    You know, if you wanted facemelting top end. XD Just mount a stock happytime in frame, and when you get up to speed, declutch. the happytime is just there for boosting up to speed.
  11. gphil
    gphil Member
    Jan 9, 2011
    274
    Those engines are gonna keep going until they will fit nicely on a ultralight aircraft. After all they ended up putting modified snowmobile engines on them. But this is a bicycle discussion.
  12. tigmaster
    tigmaster Member
    Jul 17, 2011
    139
    That would be perfect for a shaft drive bicycle,kind of a BMW!...I think it needs a flywheel for some rotating grunt....Just a thought/While I was wondering....Tigmaster....
  13. NEAT TIMES
    NEAT TIMES New Member
    May 28, 2008
    1,964
    Gphill
    Now there is an idea! In the northern states there are lots of junk snowmobiles with engines and the cvt parts for some real power! For those that have good insurance.
    Ron_______________.duh. ___________ cvlt1
  14. azguero
    azguero New Member
    May 2, 2011
    30
    i have actually been looking into the propeller idea, i have heard that it actually is pretty effective and cheap/ easy to do once i can get my hands on a prop i am going to mount a weedeater motor on a rack on the back of a giant awesome, however i do recommend using a shroud of somekind the ones ive seen are just open (nothing like taking the heads off of pedestrians i guess) im definately using a shroud
  15. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    Check out Countach Weeedeater with a propeller. http://motorbicycling.com/showthread.php?t=13950
    .cptr.
  16. donphantasmo
    donphantasmo Member
    Oct 3, 2010
    360
    I have to say, I don't think it's what most motor bicyclist are looking for. The reason we have motorized bicycles, is for cheap, economical transportation. I love the idea of buying a 100$ bike, put a 150$ engine, and I have a motorized vehicle that can take me from A to B.
    To buy a 700$ engine to put on a bike, why don't you just buy a cheap motorcycle or a scooter?
  17. Tohri
    Tohri New Member
    Aug 28, 2010
    159
    In the intervening period between my post earlier and, well now, I discovered the joy of thirty year old french mopeds.
    To all motorized bicycle lovers: Everything you want and more exists in the moped kingdom. Buy a puch or motobecane off craigslist, replace the seals and bearings, and blast.
    ... Also, they have real pipes, and 6 port cylinder insanity that makes the China girl look like a lawn mower. I have seen the top of the mountain, and it is Variated.
  18. azguero
    azguero New Member
    May 2, 2011
    30
    yea thats almost exactly what i was thinking of doing.. but unfortunately i dont have the means at the moment, i dont even have the money for an engine lol i have a snowblower motor and a chainsaw motor and cant get the resources to do either build ive been trying to sell my gary fisher bike but no bites so far but it'll come someday (someday ill have a welder) also youtube ryan's airbike to see one in action .cptr..bt. also i think adding some bouyant outriggers would be great all you'd need is wings for land, sea, AND air
