New motor,No go!!!
Discussion in 'Motorized Bicycle General Discussion' started by Decedent, Jun 21, 2009.
  1. Decedent
    Decedent New Member
    May 15, 2009
    Hey everybody,I've seen a few threads on here about people installing new motors and them not starting up. I am having the same problem but I tried most the solutions that I have seen and nothing is working.I can get spark when the plug is not in the motor but when I install it,the motor will not fire.If anybody has suggestions,please shoot them my way.Thanks:-||
  2. Creative Engineering
    Sep 20, 2008
    1,668
    Is this a new engine installation?
    Jim
  3. Decedent
    Decedent New Member
    May 15, 2009
    Yeah,I just got the motor about 3 days ago.I have it mounted and everything is hooked up.
  4. crix2k
    crix2k New Member
    Jun 21, 2009
    if your carb is mounted at an angle, you may have problems. my friends bike wouldnt start because of this
  5. xlite
    xlite New Member
    Jun 18, 2009
    736
    If spark is ok then it must be gas. Make sure the float bowl is full. I suggest taking filter off and squirting some into the mouth of the carb. Try starting on a big hill too. This usually gets things going.
  6. Bikeguy Joe
    Jan 8, 2008
    11,529
    If you have spark-
    Confirm fuel flow to the carb.
    Push the primer button for 3 seconds.
    Pull the choke lever almost all the way up.
    Pedal relatively fast, like a good bicycle cruising speed, and release the clutch.
    Work the throttle a little and see what happens.
  7. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    turn fuel petcock on. choke on carb up. push primer button like 3 times.
    get on bike and peddal fast and release clutch and keep peddaling. if started pull clutch in and stop bike,give throttle and let idle ,push choke down.you may have to do all this twice.
    make sure your ground(black) wire is grounded good(engine or frame).
  8. freewheeling frank
    freewheeling frank New Member
    Mar 10, 2009
    440
    gotta throw my 2 cents worth in here, i have had lots of problems with electrical connections, so i started soldering everything it helped a lot, happy cycling guys and gals. frank
  9. captainrichhill
    captainrichhill New Member
    May 31, 2008
    203
    EITHER (starting fluid)
    Take off the airfilter and give the carb inlet a shot. If it fires then its not electrical.
    CAUTION: ONLY USE A LITTLE STARTING FLUID. A LITTLE FLUID MAKES A BIG FIREscratg
  10. Decedent
    Decedent New Member
    May 15, 2009
    Hey all,I finally got it runnin.I just had to make a minor clutch adjustment and it fired right up.I completely disassembled the carb and everything was good.I followed all the pathways for the fuel,tightened everything up and adjusted the clutch spring and BAM,runnin like a champ.I wanna say thanks to all the people who left responses and tips,it was a great help.I should have some pics up in a day or two.Cheers to you all......usflg
  11. OzzyU812
    OzzyU812 New Member
    May 15, 2008
    258
    :-|| to dance1 great!!
