new guy
Discussion in 'Motorized Bicycle General Discussion' started by bbwolf, Dec 30, 2015.
  1. bbwolf
    bbwolf New Member
    Dec 30, 2015
    happy holidays everyone!!! i am a disabled cyclist, i ride a recumbent tadpole trike, im not looking to motorize my trike but i do pull a trailer and am thinking of building a push trailer, im thinking a harbor freight motor, centrifugal clutch, mounted over a single wheel bob trailer, but have some questions, when im riding pulling my trailer is there gonna be any drag or resistance from the clutch?
  2. 2door
    2door Moderator
    Staff Member
    16,301
    25
    Welcome to the forum, Wolf. We're glad you've joined us here.
    Typically you'll see little resistance from the drive system with a centrifugal clutch. When the friction pads of the clutch are disengaged, as when the engine isn't running or up to the required RPM, the drive system will simply free-wheel. Of course there can be some parasitic drag from things like the drive chain, sprockets, bearings, etc.
    We would need to know more about your proposed drive system to give you a definitive answer. If possible please post a photo of the system you are planning to use.
    Good luck.
  3. Ludwig II
    Ludwig II Well-Known Member
    Jul 17, 2012
    4,706
    41
    Some sort of freewheel device at the driven wheel would take care of it, surely?
  4. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,475
    44
    that would probably do it - where do you get one?
  5. bbwolf
    bbwolf New Member
    Dec 30, 2015
    i have no idea? the trailer i pull now is made out of 3/4 conduit 3 foot wide about 5 foot long really light weight, 2 - 20 inch wheels, the hitch is a bob nut type set up coming off axle, to keep cost reasonable i was hoping to keep simple
    harbor freight side shaft motor either the 6.5 hp or 3 hp both same cost, with centrifugal clutch, i have no idea about anything so any help tips tricks advice suggestions pics plans whatever is appreciated
  6. Venice Motor Bikes
    Mar 20, 2008
    6,169
  7. bbwolf
    bbwolf New Member
    Dec 30, 2015
    well guys i changed my mind i think, i been looking at a 16'' electric wheel and thinking i may just motorize my bob yak clone trailer, thing is i dont know who the best venders to deal with are,
  8. sbest
    sbest Member
    Nov 3, 2015
    343
    The problem with electric is
    1) the weight and cost of the batteries, and
    2) the short range and low speed between charges
    While it may only cost pennies to charge an electric, a vehicle the weight of yours would typically only travel at 15-20 mph for about 10 miles give or take 50% depending on many things.
    Lead acid batteries are the cheapest at about $100 to $400 depending on capacity and voltage and you are looking at 50 to 100 lbs in batteries. Their typical life is about 2 years. Lithium batteries are less than half the weight but are 4 times the cost and at least double the life if you don't burn them out, which is very easy to do. So batteries are the big cost and problem and weight.
    To keep all this weight rolling at 15mph you are going to need 500w to 1000w min, ideally geared to your pedals so you can use all the power on hills. A hub motor or hub drive isn't going to cut it.
    Gas engines are not all equal. The China Girl motors are cheap and simple and complete, easiest and lightest to hook up. They are not the best word in efficiency and you have to be a bit of a hobbyist to get the most out of them. Most utility 4 strokes are only moderately efficient, but easy to hook up and you are only looking for 3-4hp for 15mph which is all you want with a bike and trailer. Again, ideally it would be best to have it geared or hills are going to be a problem, but then, you only have 10-25 lbs more.
    I guess distance is the deal breaker. Longer distance you need gas, urban short distances make electric king.
    Steve
  9. bbwolf
    bbwolf New Member
    Dec 30, 2015
    thanks sbest, you are absolutey correct the only way to get decent run time is to go with lithium batteries but they gonna be really expensive, and i talked to a guy today that has had alot of problems with his chargers, and already burned thru a few controllers, and had nthe magnets bust loose on one hub, that convinced me to reconsider going gas
  10. bbwolf
    bbwolf New Member
    Dec 30, 2015
    ok guys i bought a 3hp predator from harbor freight, can anyone tell me about left hand drive freewheels? where to get or how to convert?
