new engine
Discussion in 'Motorized Bicycle General Discussion' started by gunfighter-bull, Jun 20, 2012.
  1. gunfighter-bull
    gunfighter-bull New Member
    Jun 6, 2012
    9
    With a new engine. Is it going to be still and hard to start?
    I went adjusted the cluch. But the engine is hard to turn over
  2. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    If it is difficult to turn over with the spark plug removed then something is wrong internally.
  3. GSX
    GSX New Member
    Jun 15, 2012
    14
    +1. If you have any mechanical skills take the head off and try again. If all looks good, pop the jug off and go from there.
  4. Bradums11
    Bradums11 New Member
    Jun 20, 2012
    Hi I just put together mine and I used 16 to 1 ratio and I poured the oil in to the tank then the gas after reviewing this I thought that I should have mixed it and then poured it in. What type of oil do you use? Also I got it running for a minute after trying about ten times for the first start up. Each time it progressively got better. But I gave up do you think any of this is a problem.
  5. Toadmund
    Toadmund New Member
    Jan 19, 2012
    792
    Bradums11,
    Sounds like you are gulping oil that is concentrated at the bottom of the tank and into the fuel line and filter, that's where some of the oil you dumped into went to. And as the mixture got more correct, it ran better.
