New Bottom End
Discussion in 'Motorized Bicycle General Discussion' started by fischer550, Sep 16, 2015.
  1. fischer550
    fischer550 Member
    Mar 24, 2014
    234
    I very badly damaged the crank case on my bike, so I'm getting a new bottom end (with a new crank) I am going to be using the same piston, rings, and top end I have used for 300 miles.
    Do I have to start the break in process all over?
  2. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    If you're using the same cylinder, piston, and rings all you'll need to do is put everything on the new bottom end and you won't have to re break it in, the main reason for breaking an engine in is to seat the rings so you'll be ok as long as you're using all the original top end parts.
  3. LandSpeedRecord
    Dec 11, 2014
    604
    Ha ha in the time I was posting a reply Dave said the same thing. What he said⬆⬆⬆⬆⬆
    #3 LandSpeedRecord, Sep 16, 2015
  4. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,771
    88
    should be no problem is both rod length & crank stroke are the same - so many diffs out there now : (
  5. fischer550
    fischer550 Member
    Mar 24, 2014
    234
    So absolutely no break in for a brand new bottom end? I can just run wot from the start like ive been doing?
  6. crassius
    Sep 30, 2012
    3,771
    88
    may not be needed, but I like to go gently on bearing surfaces that are new and finished by a chinese factory rather than one with good quality control
  7. fischer550
    fischer550 Member
    Mar 24, 2014
    234
    this is a dax bottom end
  8. Davezilla
    Mar 15, 2014
    2,708
    Dax bottom end = No Worries... That's all I use when building up a performance engine...
    No issues at all so far
  9. fischer550
    fischer550 Member
    Mar 24, 2014
    234
    ok I'm just not gonna break it in at all then
