Need some basic info.
Discussion in 'Introduce Yourself' started by ReallyOldGuy, Aug 19, 2010.
  1. ReallyOldGuy
    ReallyOldGuy New Member
    Aug 19, 2010
    6
    Hello: Am completely new to motorized bike. Have ordered my first kit...expecting it to arrive Monday. It is a center mount, with a rear wheel, chain drive to a separate sprocket. I am thinking of converting my old Trek Mountain bike. My very basic knowledge of engineering forces me to ask the question. Except when pedaling, what effect does the multi gears have when using the engine? The reason I ask, is that I might want to opt for a more comfortable Cruiser bike instead.
    Know this is a dumb question, but I am advanced in age and it has been a really long time since I was in school.
    Appreciate any advice.
  2. azbill
    azbill Active Member
    May 18, 2008
    3,367
    welcome to the forum :)
    unless you have a shift kit,,,the gears will only be used when pedalling ;)
  3. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    16
    Welcome to the forum, glad you joined us.
  4. Bikeguy Joe
    Jan 8, 2008
    11,529
    The multi gears will allow easier pedaling if the engine quits, the drive chain breaks or you just want to pedal, nothing wrong with them. The sprocket is actually easier to mount on a multi speed type than a coaster brake type too.
  5. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Take a look at how the existing brake and shift cables are routed on your Trek. They might be in places on the frame which make it inconvenient or difficult to mount the engine or tank without interference.
  6. ReallyOldGuy
    Aug 19, 2010
    6
    Thanks Nougat: I did that earlier...there will be a problem with the gas tank, but I found a work-around using somethinglike body putty that will adhere to the metal frame, and by pulling and pushing the cables during the drying time, will allow free movement of the cables after the stuff is about half cured. ..then mount the tank before completely cured. If that does not work, then I can mount the tank behind the seat on the carrier. There are other bugs as well....still thinking about just buying a cheap bike that does not have these problems.
  7. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    With a cruiser, you'll need to deal with a front engine mount, but those are available off the shelf now.
  8. kipharley
    kipharley New Member
    Jul 9, 2009
    647
    Old is just a state of mind!Welcome.I built a motorized Trek mountain bike.the rear cables ran over the top of the top tube.I just built a little bridge over the cables with a piece of exhaust pipe split length wise and tacked it to the frame.
    It is easier to build one using a cruiser thou.
    If you are like most of us use that one as a learning platform.Then sell it and build a better one.
    I'm on #20 and counting and I've only been doing it for a year!
    P.S.I'm an old fart too.I have underwear older than most of these guys!!
